Dtc P0141
I am getting an O2 sensor trouble code, P0141, which refers to bank 1, sensor 2. Which side of the engine is bank 1 on? Passenger or Driver side?
Which brand? Bosch or Denso?
Bank1 is on your drivers side. Cylinders 1,3,5,7 are one the drivers and the passenger is 2,4,6,8 thus being bank 2
ac delco plugs works the best for gm trucks
Driver side follow the pipe from the left manifold it will twist and turn,sensor 2 will be post catalytic converter(sensor just AFTER the catalytic converter).I would go with a denso my self,but bosch would probably be o.k. also.Hopefully the old sensor comes out without yanking the threads out,have a TAP handy in case you need clean the treads up in the pipe.
  • 1 month later...
So, I replaced the O2 sensor with a Bosch. Cleared the code. It has come back a couple times since then. This last time it was gone for two weeks.
How do I get rid of this error permenantly?
  • 3 weeks later...
Alright, I can't seem to get rid of this code. Wiring all looks good. I replaced the O2 sensor with a Bosch. When I clear the code, it always seems to come back a few weeks later.
Should I try a Denso sensor instead?
Would a battery that is aging cause this? KOEO, I get just below 12v, 11.88 at the heater circuit. While idling the battery reads above 14v and 12.8v when turned off.
What about a sticky t-stat? I notice first thing, the temp goes all the way to the middle of the gauge before dropping to 1/4 and then stays there while driving.
I don't to just throw parts at this, I could use a little guidance.
just unplug your engine light bulb haha. i did that. I had like 5 codes a day about my dam 02 sensors. i cut my cats out thats why. i hook up truck up to a scanner weekly anyways to catch stuff.
I am the kind of guy who fixes things, not ignore them. Even though the light isnt always on, I know the problem still exists.
yeah i agree with yeah on fixing it. i usually fix stuff on my truck and pretty anal about stuff. i Had my cats cut out and replaced with high flows and my light was on anyways so i cut them off in a whole hurry. then after a while with dicking around with them trying to fool the computer i gave up and just unplugged the bulb cuase i had to replace a couple bulbs in the cluster anyways haha
More than likley the wrong o2 sensor was replaced,did you follow the driver side exhaust pipe all the way over to the 1/2 o2 sensor visually? the pipes sometimes twist around and you can loose track of which sensor downstream is coming off of bank 1 & bank 2.
Other then checking the wiring to the sensor,try switching the new o2 sensor with the other downstream then reevaluate or swap the one you took out first and install it into the other ones position and see what happens.
  • 3 weeks later...
You know, when I read this, I kind of laughed. I was sure I replaced the right sensor. For the heck of it I looked under there today, I was wrong.
The driver side downpipe snakes over to the pass side and then back.
I put the original O2 sensor in its place and we will see what happens.
For what its worth, the CEL has been out and no codes for a couple weeks, just coincidence?
Thanks VRSCA1
Thanks VRSCA1
Your not the first one to do this.....I have been there done that myself once....ONCE!
Probably will be fixed now...Was a common error made by many incuding myself....used to see it often when I worked at the dealer.
Thanks VRSCA1
Not a coincidence if you confirmed visually that the incorrect o2 sensor/location was being addressed.Glad I could help out.
The CEL has been gone for a couple weeks before I noticed the mixed.
Should be fixed now, I would think.
  • 4 weeks later...
hey guys,
so i have had knock sensor go bad and the guy before me prob never did get it fixed till i bought the truck, anyways, after new intake gasket and cleaning some sort of debris out of the drivers side injectors, i am now having the rear O2 sensor tripping a trouble code, think its related or just finally going thru its checks and noticing catalyst is out of wack? my freeze frame info has changed a lot since the knock sensor replacement and missfire issues....
Chris
    • It really doesn’t matter to me. Making a blanket statement that can be refuted will be. As I pointed out the information is out there. Hey google.
    • My area is one of the most affluent areas in Texas. And yet affordable housing is close by. My family business pays top wages and turnover is very low. You can’t but people in a box if you want to succeed the opportunity is there.
    • It was previously working, but the continually running compressor threw me for a loop. It wouldn't be out of the realm of possibility that a 26 year old AC system had lost some of its charge and could be exhibiting low charge indicators, so I thought I had it licked. Add some refrigerant to get the low and high pressures in range like on the old 134 systems.   I learned the continuously running compressor is normal, and that I need to know how much is in the system, as well as needing to meter what goes in. I'm only used to working on older R134a and R12 systems that aren't variable displacement. This is how we learn...LOL.   Long story short, I had a 20% off coupon for a new Jiffy Lube that opened nearby. I took it up there yesterday and they did an evac/recharge using their brand new machine from Mahle. Had a good conversation with the guy, they loved the car and I was out of there for $159 plus tax. Digitally measured charge, exactly 1.5lb of refrigerant went in.
    • In most areas of the country, wages have trailed CPI increases over time (let's say, since the 70's) and things like housing, energy, and food have vastly outpaced wages on the whole. Can't ignore that, it's very real.   That isn't to say there aren't ways to live in ways that mitigate some of that, including moving to cheaper areas of the country. In KNut's neck of the world, median housing prices in "nearby" Dallas are more like $500k. If you're raising a family and young in a successful career, your economic opportunities are probably going to be better living closer to Dallas than Cornhole. A 3 hour (6+ round trip) daily commute probably isn't tolerable for most folks. Grumpy mentioned economic migration; but we've seen what happens when people populate and grow an area. It becomes more expensive when economic opportunities come to roost.   One thing different now from back in the 70's is our quality and standard of living has changed. Healthcare is light years better, for example. But it's also much more expensive. And we have communication and information/tech tools that folks in the 70's could never imagine, and they're accessible to people of just about all incomes. Cars are light years safer, faster, and filled with tech advances. Homes are larger, more energy-efficient, and more luxurious on the whole, from starter homes to luxury homes.   Seattle was once affordable. My folks came here in the 70's with a lot of other people from California looking to escape uncontrolled sprawl, smog, and rising prices in the Bay Area. Seattle and the surrounding area has grown considerably; The home they bought for, I think it was $70k or $80k in the late 70's is now worth $1.2M today. The same house.   So while there have been obvious boosts in some areas of quality and standard of living, regarding opportunity, that's a bit more nuanced. It's really not possible for young people to get started in similar situations in areas of the country that have become "HCOL" (high cost of living). There are many more areas than before, which is to say they exclude younger workers or make their lives significantly harder. They have to commute farther and longer to afford to live in the area. They have to take outsized risk, take on more debt, significantly delay family planning. Or, they could move somewhere cheaper, but there's usually a loss of economic opportunity that comes with that. Even for the same job, it may pay a lot less in a LCOL.   What I don't like are Boomers with phones thinking they have all the answers and outright saying that if people stopped paying for their cell phone that they'd be rich. It's as stupid and misguided as people who think they'd only be rich if taxes weren't so high. Sorry guys, Elon proved you wrong on that one, I guess you're just lazy and blaming your own situation for the reason you're not wealthy. Mobile communication is basically an expectation in a modern society and workforce and it's often cheaper than having a copper landline these days, so... What's your point?
    • My 2008 started exhibiting similar symptoms, wasn't 'cold' enough. I went through a pretty extensive diagnostic process for a DIY'er with limited OBD access. System evacuation and recharge included.   Noticed one day the passenger side was cold (I'm never over there so took awhile to notice).   Pulled the drivers side blend door actuator out, disassembled it and cleaned it out. Put it back in and did some kind of reset and it fixed the problem.   Long story short, it wasn't the A/C system at fault, the blend door wasn't moving to full cold position.
