Under Seat Storage
If you're referring to the GM underseat storage box, the answer is yes I have it; and I love it. I have it loaded up with all my tie downs, tools, towing stuff, etc.
I just went buy a plastic storage container from walmart and it works pretty well. sometimes it will slide out from underneath if I break too hard but I'm planning on putting a piece of rubber or something underneath. I didn't even know GM made a under seat storage bin.
Put stick on velcro under neat the bin, the rough side. It will grab on the carpet.
Have the GM underseat for 09 CC...works well and is very sturdy. Anchors well with two small bolts into female part attached to the seat belt anchor. Need room with seat up, just remove the two bolts and pull out the storage..no need to empty to remove...
I have a 99 GMC NBS GMT800 3 door Extended Cab. Box comes with brackets and covers for 3 door and 4 door. Good box. I keep my scan tools in my box. It locks so if I leave my truck with my scan tool in it I can lock it and keep the honest guy honest I managed to stuff a Genisys with scope and all cables in the box and on the other side another scan tool..
Jbo
Does anybody have the GM underseat storage box along with weathertech rear liners? I'm wondering if the liners would prohibit installation of the underseat storage because of the thickness or inability to access mounting points...? :)
I don't know about the thickness issue. There is about 1/2 of gap between the box and the seat. The box mounts with a zig zag piece of flat stock that attaches where the seat attaches to the floor so that should not be and issue.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
