Oil Question
SCE_Razor
What kind of oil is in a new 2009 GMC Sierra 1500 Pickup right out of the factory?
5W30...as for brand...who knows.
If it has a sticker on the oil cap saying Mobil 1...than that's what it is (Mobil 1 5W30 Synthetic)...other than that...whatever was in GM's barrel at the time.
It's my understanding that GM has a supply agreement with Exxon-Mobil for lubricants. The factory fill is very likely 5W-30 Mobil, very similar if not identical to Drive Clean 5000 you can buy in stores. The GM Goodwrench branded oil is also a Mobil product.
Whomever provided the lowest bid. What may be factory fill in one plant may be something completely different in another. Most GM lubricants come from Petro Canada.
This is true at most dealerships too.
As long as you get top grade correct weight oil, you are good to go. Everybody has a PREFERENCE but that's really all they are in spite of how much I will argue with you that my Amsoil filled crankcase is superior! :lol:
The stuff the dealer uses (GM Goodwrench) can be anything from Quacker State, Pensoil, Mobil, Valvoline, or some cheap wal-mart brand. As long as it meets the oil specs called for in the owners manual.
There's the key statement. Follow that and you have no concern...your engine will last longer than you want to keep the truck in most cases.
Pretty much it. Sorry to say the lowest bidder gets it all in the lines of saving money and the GM bean counters do there job at that. Not to say the oil is inferior but it isn't top of the line either. I would meet the specs call for by the GM engineers. Mostly a 5w-30 grade oil as well.
Oh and some advice, never argue with "The Clown" :thumbs:
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
