Nav/dvd Player Making Noise When Yukon Is Off/also Engine Noise Questi
When I open the door to my Yukon while it's in the garage, I hear the Nav/DVD making noise like it's reading the DVD, you know that CD/DVD noise it makes when it's accessing data. Is this normal? This is with the truck ignition completely off.
I've left my truck parked for over two weeks while out of the country and it started right up, so it doesn't seem to be draining the battery.
Other question is under moderate throttle around 2,000rpm give or take a few hundred rpm on either side, my engine makes a bit of a rattle noise like something is loose under the hood. It's a resonance type rattle and it seems to happen pretty much all the time in that rpm range with medium throttle. Someone posted up a TSB a long while back about the right wheel fender area or the radiator fluid container rattling, but I can't find it. Anyone experience this and/or know a fix?
Otherwise, I have 25k miles on my '08 Yukon and she's been flawless. I love her.
Yes, the noise from the NAV unit is normal. Mine does the same.
Not sure on the rattling, I would have to hear it to know if it's "normal" or not.... but keep in mind that a bit of resonant drone should be expected as normal under certain acceleration conditions from the large V8 in that truck. At cruising speeds it should quiet back down though.
The Nav will make that noise any time the door is opened. The first few times the wife's Tahoe did that it threw me for a bit of a loop as well. As far as the TSB, I think the bottle was contacting the fender so you could try some 3M double sided tape to act as a cushion. That might work. :lol:
The rattle noise your hearing if its the same alot of us had is the heat shield under the passenger side at the exhaust by the motor, I had the same noise and with a couple of hits with my hand to bend it a little problem was solved.
thanks for all the suggestions, I will give the double sided tape and also the heat shield a try and see if it works.
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
