Wheel Spacers
whizbanger1
I am thinking of adding spacers to push the rear tires out. I would like to match the front track, maybe a little wider. Any idea what size I would need? Thanks.
As said wheel spacers put ALOT of stress and leverage on the wheel bearings. Much like using a long pipe on a pipe wrench handle to break something loose.
The front track is wider for a reason as you dont want the rear wheels rideing in the same track the front tires do as this is for added traction for the rear. This is why the front track is wider in the front on 4WD vehicles.
  • 3 months later...
Thanks for the info. I forgot I even made this post. I just don't like the looks of it. Maybe I will look into aftermarket wheels. I always liked the look of a wider rear end.
just to play devils advocate, im not a physicist mind you, whats the difference between using a 2" wheel spacervs wheels that stick out an extra 2"... that would be like saying using a 12" pipe wrench with a 2' pipe on it will give you more power than using a 3' wrench with no pipe on it... am i thinking bout this wrong? if i am please correct me.
J
It's how everything mounts and where the pressure is applied and how. It's really not as simple as a leverage argument. It is more about how the front assembly was engineered to handle stress.
