Whoot ! Who Dat!
Norseman
Nice to see another "New Champ!"
One day my beloved Browns WILL be there!!!
The Browns have the most loyal fan base in any Pro Sport. I love that. That's what sports should be about. Loyalty and Honor.
WHO DAT!
