2003 Sierra Brakes
My 03 Sierra RCSB 4x4 has a tad over 160,000 miles on the original front brakes, and they still have some more life left in them, I have never had a set of front brake pads last so long in my life.
Now a couple of disclaimers:
The truck has a lot of "interstate miles" which is the best case scenerio for brake longevity but it also has spent a huge amount of time in the swamps (MUD) of SC as well so that kinda evens things out. Not to mention a huge amout of towing.
Before anyone makes a comment about the brakes being changed without my knowledge, I bought the truck new and I am the only one that has ever worked on it, Period.
I did replace the rear disc pads at 120,000 miles.
These trucks have the best brakes of any vehicle that I have ever owned, Kudos to GM.
Has anyone else had this kind of service from the brakes on a GM truck, or any vehicle for that matter?
The last time my old '99 K1500 was in the shop here the guy had almost 160,000 miles on it,and it also still had the original front brake pads on it!!!
I had to put new rear pads and rotors on it around 65,000 miles,the right-rear inner pad was wore down to nothing,the other three still had plenty of meat on them!!
I also had to put new front rotors on it around 75,000 miles.
Never had to do anything to my '04,but it only had 29,000 miles on it when I traded it for my current '07.
I haven't put a set of pads/shoes on any of my vehicles in a long time.
Even my trucks that I use to snowplow or tow never needed any brake
attention in the 30k miles I put on them till I traded them.....................
Now my dad on the other hand had 4 sets of pads/rotors in his 02 s-10
in 20k miles !!!!!!!!!!!! His 05 Dakota has had 2 sets and needs another
set at 32k miles! Hes smoked several sets out of moms Cadillac too!
But to be fair.......He does ride the brakes and swears he is just "resting"
his foot on the brake pedal and NOT pressing on it !
He claims GM and Mopar use cheap pads and rotors! LOL!!!!!!!!!!!
the front and rear rotors on my 2003 suburban lasted 120k miles and the front pads lasted 90k... gmt800 trucks have awesome brakes stock imo
Whatever the GM engineers came up with in terms of pad material and design, they all deserve medals! :shakehead: I traded my '99 Silverado when it had 77K on the clock and the front pads still had 50% left and the rotors looked like new. The rear pads and rotors looked even better.
If this level of quality was carried on to the GMT900 trucks, some brake parts manufacturers are going to have trouble with their profit margins.
I can tell you from my experience the "level of quality" has not carried over to the GMT900/
I just replaced my front, and rear pads and front rotors.
The pads fell apart in pieces when removed and the rotors were "moderately pitted" (words of the mechanic).
My 08 has 18,000 miles on it and mostly highway driving. My 04 Colorado had 72,000 and the pads / rotors were in great shape when I traded it in on this one.
Mechanic says he was not surprised as he is doing this to a lot of GM trucks anywhere from 17,000 up to 25,000 miles
I did not put OEM stuff on as a replacement
My 08 has 45,000 miles on it so and I have not even looked at the brakes, I guess I need to do so before too long.
ac delco parts rock man, plain and simple
haha true except for the alternators
Alternators are Delphi parts anyway :shakehead:
Whatever the GM engineers came up with in terms of pad material and design, they all deserve medals! :P I traded my '99 Silverado when it had 77K on the clock and the front pads still had 50% left and the rotors looked like new. The rear pads and rotors looked even better.
My 08 only has 13K on it but I have done some towing since I bought it and sometimes I'm pretty hard on the brakes in street driving. The rotors still look like new and there doesn't appear to be any more than 10% pad wear so far on either the front or rear pads.
I have 177k on my 01 2500 4wd. Never has had the pads changed. I bought the truck in 05. Truck was serviced at the local Chevy dealer. I sell parts to the service and parts department at that dealership. The service manager hooked me up with the records on the truck after I bought it. The bulk of the stuff on the records the receipt was gave to me when I bought the truck. I use this truck to; tow hay with in the summer and pull tractors from place to place. Now, I do say I have 2x 10k axles with brakes on the trailer. I have been amazed that they are still hanging in their. Last Time I had it apart and sanded the rotors and pads the fronts had like 4 or 5mm of pad left and the rear was just a bit worse but not to the wear squealers.
I had the brakes changed on my 1999 when I purchased it in 2001 at the same dealership (got it kicked in the deal with the purchase) all the way around. Rotors were warped pretty bad and the E-brake did not work. The guy that had the truck before me likes to pat the brakes.... That was at 31k, I changed the fronts again at 75k due to squealing and rears about 100k squealing, then again at 16xk when I changed all the brake hoses. Pads were never that bad I changed them anyways as well as either turned or replaced the rotors.
Jbo
Edit: The GM edge code is still on the pads on the 01 2500..... Providing somebody else on here knows about edge codes.
mine "just" passed inspection back in November. The dealer told me to bring it in in six months for a check because he was almost certian I would have to have new shoes put on. It was my first annual inspection after buying the truck. And yes I bought it new.
From previous brake discussions I think it really depends on where your truck is located - somewhat real winter or no snow easy. See the picture of my 2002 at about 30,000 miles for the front brakes. Rear locked up at 44,000 miles due to rotted calipers.
As they say, your milage may vary - oh yes the rear backing plates for the discs that attach to the axle flange are also well rusted away on my truck - but still holding. Truck spent a year or two in NH before I bought it down in the DC area - mild winters until this year. Rest of the truck looks good, but the brakes are the worst.
Mike
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
    • This is going to take allot of Assembly
    • Why do they have the gas 10l80 opening at 145?
