Transfer Case Model #
I need to know my transfer case model number. How do I find out?
Here's my truck:
2007 GMT-900 Vortec Max 6.0 w/NHT package (heavy duty trailering)
I think I just found the model. I believe it is MP3023
Now I need to find the High and Low range of this transfer case.
High range: 1.00:1
Low range: 2.69:1
Thanks for your help everyone! :lol:
NQH-LD 27T
Can you or anyone show me where I can verify this. All the info I googled says NQH = MP3023.
I can't find any mention of a "LD 27T" anywhere.
NQH-LD 27T
Nope, I'm giving it off the top of my head. 07 half ton has 4 speed trans which has a 27T output and half tons are the light duty transfer case which has a 1.25" rocker pin chain.
There is no model stamped in those units, only a serial number. The tcase originally has a sticker with the GM part number and GM broadcast code. Even if the sticker has not fallen off I don't think you can read it in the vehicle. The sticker is towards the front of the transfercase at the top.
NQH-LD 27T
OK...so from what I have been reading you either have an NP 236 or an NP/NVG 246
I would wager money on the latter as it more describes what you should have....mostly the number 4...Part time plus full time, electrically shifted. #3 says its a Part time electronicly shifted case...more like what should be in the 2500 model. Basically, how it reads to me a 246 has the auto position and the 236 does not.
NP/NVG T-Case explained:
http://www.bc4x4.com/faqs/yj.cfm?cat=6&faqid=162
I am not 100% sure if GM stuck with the NP/NVG T-Cases in the NNBS trucks though.
