GMT900 3" Body Lift -- New
This is a feeler sale. I got this as a trade for something else from another member on a different forum but I am thinking about selling it now. I am currently looking for a house and I don't want to lift my truck too high just yet. Just incase the garage in my future home has a shorter door. I really want to keep it but if someone else can use it I would rather have them have it for now.
So what I have is a Brand New PA 3" body lift for all NNBS 1500 trucks. Part#10193. I also have a set of Zone Offroad 3" body lift bumper brackets for the front and rear. These are way better than the PA ones with less work for mounting them.
All of this for $300 plus shipping.
Everytime I'm in the for sale section you are doing something different with your truck. Anyways I love the way your truck looks and think you should keep it the same for more than a week :cheers:
Free bump
Free bump
I know but it keeps me out of trouble!!!! Plus I pass along a good deal on my stuff to my fellow members!!
Does anyone read the "rules" at the top of the page??? Please use the GMT### not NNNNBBBBBSSSSSSSSSS
Sorry I missed that. It will not happen again!!!
Great guy to deal with!!!! I installed the grill I got from you today, I love it. TTT
Thanks alot.
Bump for a good guy to buy from. Would buy from him again with now worrys. :crazy:
how much is shipping to 76801?
just curious.
also, how much would i expect to get a shop to install it? i dont have anyone to help me out here.
    Greg3160
    Greg3160
  • Who's Online   4 Members, 0 Anonymous, 800 Guests (See full list)
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
    • Im in the same boat. Carlink adapter comes tomorrow and dev account is in process. Would you he able to send the new instructions my way also? Question, do you have to change code and republish app everytime developer updates? Thanks for your assistance, truly the only thing i cant stand about my truck is the carplay limitation
    • Parts department or service department at the dealer.
    • I’ll take the blue one!
    • And Google AI says......... Yes, your truck can technically handle it, but you will be right at or near its maximum limit. A 2016 Chevrolet Silverado 1500 High Country with a 6.5-foot bed has a maximum payload capacity of approximately 1,770 pounds.Weight RealitiesLoad weight: Half a cord of dry hardwood weighs roughly 1,100 to 1,500 pounds depending on the wood type (like oak or hickory).Payload limit: Payload includes the weight of the wood, you, any passengers, and a full tank of gas.The math: If you weigh 200 pounds and have a full tank of gas, a 1,500-pound load of wood puts you right at that 1,770-pound ceiling.Safety TipsCheck the yellow and white sticker on your driver-side door jamb for your truck's exact payload number, as high-end luxury trims with extra features have slightly lower capacities than basic trucks.Expect the rear end to sag noticeably.Drive carefully, avoid sudden turns or stops, and keep speeds low if you have to travel a distance.
