What Rated Jack And Jack Stands Do You Use?
I am shopping around for jacks and jack stands, and being that the 2500 is really heavy, would like to know what rated weight I should be going for on a jack and jack stands. What do you guys use?
I scored a pair of 6 ton AC Delco stands a number of years back and have used them numerous times. I actually got another pair of 6 tons at Harbor Freight too. Bigger is better when safety is the main concern.
No problem. We had Murray's Discount Auto here, which has since been purchased by O'Reilly. I just checked their site and they offer the AC Delco 6 ton stands for $50/pair.
Even with a CCLB Duramax the truck won't weigh more than 4 tons. Plus you'll never be lifting the entire truck at once anyway. I have a 3 ton jack, and 3 ton jackstands. Then again if my truck falls with the wheels still on, it won't hit me anyway :crazy:
I use a pair of 6-ton floor stands, and use a 12-ton pnuematic jack.
Can't have too much I suppose. ;)
I'm looking to do a tire rotation, thinking four 6 ton stands should be safe
If I'm just rotating the tires I'll jack up the front and leave it on stands and take the tires off. Then I'll jack up the back and do the tire swap really fast with it sitting on the jack. Probably not the best practice, but I'm not crawling under there or anything.
I got a 2 sets of 6 ton stands from Harbor Freight, and 3 ton stands from sears, and a 3 ton jack from sears. I use what is close and easy to get to, so most of the time it is a set of the 6 ton stands that I have in the Garage. Also the sears jack is the older heavy black ones, but it works great and have had no problems. It does weigh a ton though!
i use the one jack that comes with the truck if i am in need of one, and just crib the shit out of the frame for safety..cheap,easy and safe
I use some home made ones from 2 inch square tubing, walls 1/4 inch thick with some grade 8 bolts. Also use some 3 ton stands, if 2 X 3 ton stands cant hold up your pickup reguardless of type.. you got something wrong cause we had my brothers cummins sitting on my set w/o complication.
Simple cheap 3 ton floor jack.
6 ton stands are overkill and are just more weight to help throw your back out when you flip down to grab em.. Could use em on a damn semi.. whole semi = 10tons.
You're only rotating front to back & keeping them on the same side, right?
A 2.25 ton (4,500 lb) jack will easily lift one side of the truck so you can swap both tires at once.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
    • PCM?  These don't have a "PCM".  Powertrain Control Module.  They have an ECM (Engine Control Module) and TCM (Transmission Control Module).   Do you mean update the radio?     You can check what version you have in the settings page.  Should be Y181 but there might be a newer build they can update it to.
