Got Blazer Back Now I Have Weird Prob
chevylobo
my 94 s10 blazer is haunted .ok now i put my 4 ways on and my dash lights blink and my lights on buzzer flashes my smaller 194 front turn signal bulb dosent light . i changed bulb also if my head lights are on turn signals dont work. at first only right signal worked but now if i put left signal on my right blinks also.
i hit brakes the right stops blinking but the left one then was blinking ok. but the right side worked nornaly u if used by its self
also when the 4 ways and dash buzzer were blinking so was my liscense plate light at first turn signals were working but weaky and only the smaller 194 bulbs werent working then it seemed to get worse i need ideas.
Sounds like a multi-function switch issue...but I'm not sure they had MFS in 94. I thought it was 95 and up.
EDIT:
I checked...you dont have a MFS.
you have a Stop/tail/Turn signal Switch, and a head/park light switch. I would be checking for a ground problem in the park light wiring, or possibly your turn signal relay is gone south.
