Procomp 6" Lift Removal
Is it a pain to go from a 6'' lift to just leveled, most lifts require cutting on chevys, can you weld the stuff back on? Utah lift laws are getting old, I think the truck would look better leveled then it does with mud flaps and giant fender flares. Also much fuel mileage difference with out the lift and 35's?
The only place that might get sticky is the front crossmember. I'd check the manufacturer's directions and see what modifications were made to install it. I'm sure it is reversible if one is willing to put in the work.
What model truck is this for? and are u going to get rid of this lift when u take it off? I want first dibs! lol
its on my 05 silverado 2500HD, and yeah i would probably get rid of it if i do deiced to take it off but still trying to make up my mind there is a lot of good things about taking it off but just wouldnt be the same head turner
Did you buy the truck with the lift on it?? Why do you want to take it off?? For towing/hauling?
Yes the lift was on it when I bought it, I just wanted to take it off for less wear and tear on the leather because I dont have steps and hopefully better fuel mileage and speed, It is supercharged and I just put a built Katech motor in it also the highway patrol is always pulling me over for something so it gets to be more of a pain then its worth. probably could of bought amp steps or flares for all the citations and impounds i've had to pay (mudflaps, flares, tint, smoked lights) All I have left to do is the flares but I cant justify buying decent looking ones like the bushwackers when only my front tires stick out about a 1/2 inch
lol holy crap, u got alot done to this truck, i guess some people are more wealthy then others! lol Wish i had that kinda money! lol supercharger, new engine, 6inch lift... hmmm 6k worth right ther easily if not more
I know what you mean, I had a 87 Chevy with 10" lift and 3" body lift running 42" Super Swampers even though my bumper height was legal it didnt look like it and I was always getting pulled over and getting my bumpers checked. It got to be so much of a pain in the butt I removed everything and put it back to stock (I saved all my parts when I built it).
I did get a fix it ticket once for mud flaps I put them on and it looked like hell and thats when I said iam done. Just not worth it sometimes. Yes I did off road with the truck so it wasnt a street queen. It was used what it looked like it would do.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
    • Yes.  The 2.7 Turbomax has Active Fuel Management.  It is NOT the same as the V8s.  Totally different system.     Here is an article from GM when the 2.7 came out explaining the cylinder deactivation and the valve lift system.  Starts at the section called "SCS Valvetrain":   New Turbocharged 2.7L 4-Cylinder Engine Powers Full-Size Trucks – TechLink         This is an internet myth going around.  It was alleged that some 5.3s had this mystical 8th digit of the VIN as an "E" which somehow meant it had a new one year only 5.3 that didn't have DFM.  The writer of said article and the person that made the claim conveniently can't count because they posted the VIN.  The 8th digit was a "D" which meant its still the 5.3 with DFM.  The 9th digit of the VIN was an "E" and the 9th digit isn't the engine code.  At all.
