Oil Pressure Silverado 2010 5.3l
I am new to this forum and GM trucks. I have never owned one before.
But I am just curious what people are getting for oil pressure in their 2009-2010 Silverados with the 5.3l Engine? I am getting about 30psi warm idle, 40 when cruising.
Is this normal or low? I guess I am just asking to know what other peoples trucks are running at and if this is normal. I am use to the dumby "low-high" oil gauge in past vehicles.
To whom it may concern, thanks for all your help.
right on the button.
My 08 has the same pressures.
That is good to know. Thanks for all the input. I won't worry about it anymore
I guess I have one other question. Did the older 5.3l from like 2000-2002 have higher oil pressure? My brother has one, a Sierra, and his seems to run alittle higher...could it just be variation in the gauge or cause it is older?
I believe the Gen IV engines have a higher volume Oil pump, so the pressure is a little lower. My 03 4.8L runs at about 45-70PSI Idle - cruising at 60Mph
a smidge above 40 psi on my 5.3 lm7 and about 35 at idle if its been running awhile...just remeber 10 poinds per 1000 rpms and you will be fine...
An old rule of thumb I've observed in some documents is to pay attention to the normal operating readings and note them down. The reason for that is because of the differences in oil viscosity when new and old, when cold and thick, or warm and thin. Oil pressure should not fall below 18 psi on the older engines and I suppose newer engines aren't much different as they are still internal combustion engines.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
