Tow Ratings
Ok I was doing some research and it says for 2010 the 6.2L with the NHT max trailer pkg you have a tow rating of 10400lbs and with the without NHT you have a tow rating of 9500lbs. I have decided to get the 6.2L without NHT so I have the 3.42 rear, but I also have the 20" wheel pkg so how much do I lose for towing with 20s instead of 18s Or do I lose much? Where can I find this out. Thanks
It will be the same,doesn't matter if you have 18's or 20's.
You'll be sorry... :dunno:
The 3.42's are fine with the denali's cause you have all-wheel drive for all that power to be delivered to. If you get an SLT with selectable 4wd, you'll have the 8.5" rear end and 3.42 gears. If you hammer on it, you're gonna blow that rear end for sure. If you get the NHT package, you get the hybrid 9.5" rear end and have the strength you need/want for towing with that much power.
JMO.. but I wouldn't think that 8.5" rear end would hold up with 403hp and then... if you add taller tires someday your screwed in my book. Heck, the 5.3's with taller tires are blowing out the 8.5" rear end.
Since your towing a decent amount of weight, thats just more stress :dunno:
Edit:
And when you do get the new truck, I would LOVE to hear how well it tows compared to the 6.0 4-speed and 4.10 gears. I've been toying around for a while on getting a 2010 6.2 with the NHT package to tow my 6500 lbs trailer around. My truck currently does pretty good, but I'm curious how much better the 6-speed does with the same weight at highway speeds and 3.42 gears.
No Steven,The 6.2 will give him the 9.5" rear axle w/rear disc brakes,whether he gets the NHT pkg. or not.
Well for the amount of time I will be pulling it, I think a 9500lb rating is plenty for a 5800lb trailer. My buddy has a 07 denali and its rated for a lot less and he has no troubles.
Learn something new everyday, I thought the regular had the 8.5" rear end :dunno:
Still be curious how well it compares.
Nope,Heres a build sheet on a 2010 GMC crew-cab,notice RPO code "AXN",Thats the code for the 9.5" rear axle,And this truck doesn't have the NHT pkg.
VIN 3GTRKVE26AG146750
VEHICLE BUILD
Merchandising Model : TK10543 -2010 SIERRA 1500 4WD CREW CAB SLE
Gross Vehicle Weight Rating : 3178 kg (7007 lb)
Order Number : NQSJDT
Build Date : 12/11/2009
Build Plant : 3AG43
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AG1 - DR 6-WAY POWER SEAT ADJUSTER
AG2 - 6-WAY PWR FRONT PASS SEAT ADJ
AJ1 - SOLAR-RAY DEEP TINTED GLASS
AJ7 - DRIVER/PASS FRT & SIDE AIR BAGS
AL0 - SENSOR INDICATOR, INFLATABLE RESTRAINT
AM1 - SEAT ADJUSTER, DR MANUAL LUMBAR
AP8 - REMOTE VEHICLE STARTER PREP PKG
ASF - HEAD CURTAIN SIDE-IMPACT AIR BAGS
AT8 - RR FACING CHILD RESTRAINT
AU3 - POWER DOOR LOCKS INCL REMOTE KEYLESS ENTRY
AXK - VEHICLE TYPE TRUCK
AXN - HYBRID AXLE
A31 - POWER WINDOWS
A60 - LOCKING TAILGATE
A68 - REAR 60/40 FOLDING BENCH SEAT
A95 - FRONT BUCKET SEATS INCLUDING: *PWR SEAT ADJUST-DRIVER 6-WAY *PWR SEAT ADJUST-FRT PASSENGER
B30 - CARPETED FLR COVERING W/VINYL MATS
B58 - COLOR-KEYED 1ST & 2ND ROW FLR MATS
B85 - BODYSIDE MOLDINGS
CJ2 - AUTO DUAL-ZONE AIR COND
C5W - 7,000 LBS GVWR
DD8 - INSIDE REARVIEW AUTO-DIMMING MIRROR
DH6 - DRIVER & FRONT PASSENGER VISOR W/ILLUMINATED VANITY MIRRORS
DK8 - CONSOLE, OVERHEAD DELUXE
DL3 - POWER HEATED OUTSIDE MIRRORS W/DR AUTO-DIMMING, TURN SIGNAL, CURB TILT
D07 - FLOOR CONSOLE
EF7 - US COUNTRY CODE
E63 - WIDESIDE PICKUP BOX
GAT - ALL-TERRAIN PACKAGE INCL: *Z71 OFF-ROAD PACKAGE *H.D. TRAILERING EQUIPMENT *RANCHO BRAND SHOCKS *LOCKING REAR DIFFERENTIAL *PWR HEATED OUTSIDE MIRRORS W/ DR AUTO-DIMMING, TURN SIGNAL *FRT & RR CARPET FLOOR MATS *CHROME SURROUND GRILLE INSERT *BODY-SIDE BODY-COLOR MOLDINGS W/CHROME ACCENTS 18" CHROME CLAD ALUMINUM WHEELS *18" ON-OFF ROAD BW TIRES *FOG LAMPS *AUTO-DIMMING INSIDE MIRROR (REPLACES STD/OPT CONTENT)
GGW - STORM GRAY METALLIC
GU6 - 3.42 REAR AXLE RATIO
G80 - LOCKING REAR DIFFERENTIAL
JD9 - 4-WHEEL ANTILOCK DISC BRAKES
JL4 - STABILITRAK - STABILITY CONTROL
KC4 - EXTERNAL ENGINE OIL COOLER
KG3 - 145 AMP ALTERNATOR
KNP - EXT TRANSMISSION OIL COOLER
K34 - CRUISE CONTROL
K47 - HIGH CAPACITY AIR CLEANER
K5L - HEAVY DUTY COOLING PKG - INCL: *ENGINE OIL COOLER *HD TRANSMISSION OIL COOLER*
L9H - VORTEC 6.2L V8 SFI ENGINE - INCL: *6-SPEED AUTOMATIC TRANSMISSION*
MSL - SILAO, MEXICO ASSEMBLY PLANT
MYC - 6-SPEED AUTO TRANSMISSION
NC7 - FEDERAL EMISSION OVERRIDE
NE1 - 50-STATE EMISSIONS
NP5 - LEATHER-WRAPPED STEERING WHEEL
NQH - AUTOTRAC TRANSFER CASE
NU5 - EMISSION SYSTEM CA BIN 4
NZZ - SKID PLATE PACKAGE
NZ4 - 17" FULL-SIZE STEEL SPARE WHEEL
N15 - FLEX FUEL
PCM - SLE PREFERRED PACKAGE: *STEERING WHEEL CONTROLS *BLUETOOTH FOR PHONE *USB PORT *LOCKING TAILGATE *EZ-LIFT TAILGATE
PPA - EZ LIFT TAILGATE
QXN - 18" ON-OFF ROAD BW TIRES
ROO - TRACKING CODE
RZF - 18" CHROME CLAD ALUMINUM WHEELS
R6J - CUSTOMER DIALOG NETWORK
R9N - PROCESSING CODE - SEAT
R9Z - POMS EXPEDITE-SOLD ORDERS/TSE
SAF - SPARE TIRE LOCK
SLM - STOCK ORDERS
SSB - MODEL IDENTIFIER
TFE - SALES INCENTIVE-COMMITMENT PLUS
T74 - HEADLAMPS CONTROL AUTO, DELAY
T96 - FOG LAMPS
UE1 - 1 YR ONSTAR SAFE & SOUND WITH AUTOMATIC CRASH RESPONSE
UJ6 - TIRE PRESSURE MONITOR SYSTEM
UK3 - STEERING WHEEL AUDIO CONTROLS
UPF - BLUETOOTH FOR PHONE
UQ3 - HIGH PERFORMANCE AUDIO SYSTEM
USR - USB PORT
UUI - AM/FM STEREO WITH CD PLAYER W/ USB PORT
U2K - XM SATELLITE RADIO
VB3 - CHROME REAR BUMPER
VG3 - BUMPER, FRONT CHROME
VK3 - FRONT LICENSE PLATE MOUNT
VPB - TONNEAU COVER - SOFT (DEALER INSTALLED)
VR4 - WEIGHT DIST HITCH PLATFORM
VT7 - OWNERS MANUAL ENGLISH
V22 - CHROME SURROUND GRILLE
V76 - FRONT TOW HOOKS
V8D - VEHICLE STATEMENT US
YD3 - BASE EQUIP FOR SCH GVW PLATE
YD5 - FRONT SPRING - BASE EQUIPMENT
YD6 - REAR SPRING - BASE EQUIPMENT
YE9 - SLE/SLT DECOR
YM8 - LPO IDENTIFIER
ZRS - SPARE TIRE
ZY1 - SOLID PAINT
Z71 - OFF-ROAD SUSPENSION PKG INCL: *OFF-ROAD SKID PLATES *HIGH CAPACITY AIR CLEANER
Z82 - H.D. TRAILERING EQUIPMENT
Z88 - GMC TRUCK NAMEPLATE
1SZ - OPTION PACKAGE SAVINGS
19C - EBONY
19I - EBONY
3SA - SLE DECOR
6ZY - COMPONENT
7ZY - FRONT SPRINGS RH
VEHICLE BUILD
Build Plant : 3AG43
OPTION CODES
AXN - HYBRID AXLE
A31 - POWER WINDOWS
D07 - FLOOR CONSOLE
N15 - FLEX FUEL
ROO - TRACKING CODE
SLM - STOCK ORDERS
T96 - FOG LAMPS
USR - USB PORT
YE9 - SLE/SLT DECOR
ZRS - SPARE TIRE
ZY1 - SOLID PAINT
19C - EBONY
19I - EBONY
3SA - SLE DECOR
6ZY - COMPONENT
Holy Cow !!!
Is there an option is DOESN'T have ??
:dunno:
VEHICLE BUILD
Build Plant : 3AG43
OPTION CODES
AXN - HYBRID AXLE
A31 - POWER WINDOWS
D07 - FLOOR CONSOLE
N15 - FLEX FUEL
ROO - TRACKING CODE
SLM - STOCK ORDERS
T96 - FOG LAMPS
USR - USB PORT
YE9 - SLE/SLT DECOR
ZRS - SPARE TIRE
ZY1 - SOLID PAINT
19C - EBONY
19I - EBONY
3SA - SLE DECOR
6ZY - COMPONENT
Holy Cow !!!
:dunno:
Yep,I can see its missing......sunroof,block heater,integrated trailer brake controller,power adjustable pedals,Navigation system,and either the power sliding rear window,or the rear window defogger.
I was under the impression that the ONLY way you could get the 6.2L in any truck other than the Sierra Denali was to get it via the Max Towing pkg with comes with the 3.73. At least that is what the online truck builder forces me to do on the GMC site. That's one of the reasons I'm leaning towards Denali. Do tell...
I had seen on the capacities info page on the GMC site that they had listed a 6.2L 3.42 combo but figured it must have been a mistake since the same site didn't seem to let me configure one that way.
John
John
Nope,You can order the 6.2 as a separate option (and could also order the 6.0 separately for the '07-'09 model-years) without getting the "NHT" Max-Trailering pkg.
Without the NHT pkg. the 6.2 comes with 3.42's,With the NHT pkg. it comes with 3.73's (The 6.0 came w/3.73's w/o NHT,And 4.10's w/NHT on 4wd's)
John
No you can get the 6.2L with the 3.42 rear in it. I just bought one today. Now I am in Canada, but that shouldn't make a difference. Also you can select it on the gm Canada website.
Congrats,... Now wheres the photos :dunno:
:P
+1 :dunno:
:cool:
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 909 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
