Do I Need New Cv Axles?
Ape0r
Maybe six months or so ago, I started noticing a grinding sensation when turning the steering wheel at low to moderate speeds. All of my front end joints are tight, steering u-joints and bearings feel good. Wheel bearings are definitely good.
I hear a light clicking when spinning the front wheels with them off the ground, and I can move the shaft between the inner and outer cv joints by hand maybe an eight of an inch.
Any reason to suspect anything other than the cv axles is making my steering grind? Am I right in assuming there should be ZERO play in the cv shafts?
What is bugging me is that it does this on BOTH sides. Did I get a bad set of cv axles from the factory? 109k on the ticker.
Thx,
Tom
ew the clicking leads me to the cv joints, how are the hubs?
Hubs felt gooood when I checked them in December. Steering sensation hasn't changed since. Totally tight and smooth. Only noise is the clicking, which points right at the cv joints. Just hoping someone can comment on whether a little play is normal or not.
phil,he said the hubs are good ,RTFP
its not your CV axles ,have a tech look at it ,DO NOT throw parts at it,
you can take them apart to see ,its not hard ,but you'll need new clamps for the boots
Yeah, the axles are supposed to move a little when you push/pull on them.
Grinding and clicking are good indicators of CV failure, but like Rob said....you cant be sure without someone having a look at it. Our idea of grinding sounds may be totally different from what you call grinding.
And 109K on a set of CV joints...assuming your stateside and mean Miles...I would say your doing good.
Spend the 50 or 100 bones and have a good shop look at it and tell you for sure....its cheaper than spending the 300 per axle and finding out it was something else.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
