Hard Time
gregrocks89
Hey everyone just letting yall know thats its been a rough easter sunday. I just got out of a 2 year relationship and i was even engaged to. So yeah pretty much hate life right now.
Shitty deal man....
It can all be fixed by slingin some mud though.
theres always more fish in the sea man, if you don't mind me asking what caused the problems?
aw what the hell, for sure sorry man...i've been in that situation before...
Sorry dude, been there done that and man did it suck. But would you rather be with someone who lies and sleeps around or someone who is honest and only sleeps with you? Just remember you were looking for some tail when you found her and you are looking for some tail again no difference.
You'll find someone new....
Just remember this when you plop your writeup on E-harmony to try and get a hook up...
That's not the right answer...no matter how true it is.
Just like the question "what do you thing would be the first thing you would feel if you shot someone" gets asked to us service members from time to time
Recoil...is also not the right answer....pick an emotion...any emotion...just don't say recoil.
hopefully I have made you laugh.
Sorry to hear you got hosed over, but hey, that's what women do (no not all , but a lot). I have two trucks, two motorcycles, a cat, and no women in my life, and everything is great. Your life can only get better from now on. Summer is coming and things are looking up.
Im engaged and sometimes I wish I wasn't. Nothing to do with her in general its just that if I wasn't I wouldn't have to worry about a house or anything that will come along with a wedding. I wouldn't worry to much man. Id just go have fun and spend money on what YOU want.
    rayredbone
    rayredbone
  • Who's Online   2 Members, 0 Anonymous, 463 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
