10monts Later And I Think Im Done
i think im done finally adding modes to my truck..
so far:
Tint
rear under seat storage
hardwired passport 8500
ARE lid with keyless entry
Blacked out GMC front logo
De-badged all the way aroung (except for front GMC)
Edge 22" chrome wheels
IPCW LED tail lights (bermuda blk)
IPCW LED third brake light (bermuda blk)
so now im looking to take some off...(factory installed items)
Anyone know how the middle of the door trim comes off ? just like debadging ? (3m tape? )
also looking at taking the chrome off the door handles and mirrors ? anyone know how these come off ?
looking to just leave it mostly black except for the bottom half of the whole truck all the way around... ( wheels, steps and bumpers)
any suggestions ?
thanks in advance
i was debating on taking the door guards (middle door trim you call it) off, but i would be super pissed if someone dented my doors, so i have left them on. i think it adds a nice contour to the body by leaving them on and it makes it look like a plain work truck with them off.
to de-chrome the door handles, you need to purchase colormatched door handles off ebay or a dealer.
if it was me, i'd leave the chrome handles because they should accent your chrome wheels and the door guard trim because it's for protection (i've slammed my door into a metal pole and it hit the guard and didn't hurt it, would have if i took it off)
basically leave it like it is and POST PICS
I would never take door molding off in fact on the other truck I had I installed a factory set on the doors. Yesterday I went out to my truck and walked around the passenger side and saw a white bump mark on the molding where someone hit it with there door from a white vehicle, I was able to wax it out but if it wasnt there it would have been a dent.
let me know if these photos work....cant get them to download...hmm
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
