Lowering help, 2000 Tahoe
I'm buying a 2000 Tahoe next weekend and want to drop that sucka!  4 door 4wd,
From the good old days I recall Belltech being the equipment of choice.  I will be towing with the truck so I don't want to compromise ride too much.  For anti-rolll I will just change out the sway bars.
Anybody dropped a Tahoe?
Welcome to the site!
I have heard some people complain about the belltechs, but I myself have no experience with them.  It will cost more money to drop it b/c it is 4wd.  You might want to think about if it is worth it to you.  How low would you like to go?
Best bet is when you're about to get into some narly, rocky or low traction situations on a mean trail air down to about 8 - 10 pounds.  This will get you the performance these TRUCKS are made for and when you're done wheeling you just air back up to raise it up to where it belongs... ;)
  • 3 months later...
  • 6 months later...
my 2000 old body Limmited was dropped.   this was a two wheel drive though.
if i were you i would call belltech and ask them they were very helpful to me.
mine had front drop spindles with stock control arms top and bottom bottom control arm had to be knoched so it would not impact the rim.  it was so close it grinded down the wheel balancing weights a bit.  we also used springs and shocks from belltech.
in the rear   on the front of the leaf spring we torched off the stock frame hanger/seat and replaced with belltech lowering hanger and there were longer shackles in the rear. the longer shackle impacted the rubber part of the gas tank fill hose but i never had a problem with it wearing through or anything like that.
i recently lifted it up since i didn't like to have to drive slow all the time.     the ride was excellent though no complaints for normal road riding.   but the speed bumps and occaional gas station entrances were a pain.   i just wanted the truck to be more robust.     but this truck was about as low as they go.  it was lots of fun and i am keeping my kit i might put it back sometime but ill probably sell i am set on a the new body tahoe with a radical lift, not to mention 4x4
check out the pics     www.geocities.com/dustee900
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
