Has anyones g80 locked itself in and failed to release acting like a full blown spool or detroit (chirrping tire around a corner) and then finally release upon backing up or stopping and pulling out again? Mine has done this twice and I really didnt think anything of it but i'm just curious.
I've also noticed that it doesnt lock in as good as it used to, if at all anymore. Being that its a 5-speed, I have a tendency to throw it side ways here and there and regardless of whether or not its good for it (we all know its bad). Well the last few times its spun only one tire and i'm trying to figure out if I blew it out or if its just worn or what. When I first got it, 4 out of 5 times it would kick in and you would have to hang on but now its not the case.
Mine has done that a few times this past winter in the parking lot at work. I hit ice which caused it to spin and when I backed into my spot it wouldn't unlock. I pulled out went down the lot made a right turn and it made a loud bang and unlocked. It was cold out and the rear end fluid was cold so I just figured thats why it did it.
Change the gear lube..
yes, changing gear lube may help ... the G80 is a mechanical locker and DOES NOT use any additive to the lube ... some people may try to tell you that you need a 'limited slip additive'... but the G80 is different, just use conventional 80W90 .. or some synthetic equivalent.
baby the thing. Paying $1600 for a new one really sucks! Of course that was $1600 for a 1500 1999 Silverado too.. Never abused the thing either. Not sure how much more they would charge for a 2500/3500.
If you want to pay the extra $$$ for a rebuild/replacement then by all means go for it. I can find better things to do with $1600 then spend it needlessly on a rebuild on the rear diff because I was abusing my truck.
why should i baby it? I'd rather it blow rather than messing with me.
Careful what you say about the G80- that may be true in the truck world, but GM calls all posi's G80- the Caprice G80 was made by Auburn, had cone clutches, and definitely needed the additive. The Camaro I own has a torsen unit for the posi, again called G80 by GM- debateable about whether you need the addictive, but it doesn't hurt- I have seen Eaton ones with clutches, too, and they needed the friction modifier- just trying to make sure that someone doesn't think that all GM G80's are the same-
RPO G80 in a pickup truck since 1973 has meant Gov Lock. That's 37 years covered so it's pretty safe info. Your Caprice Auburn would be the same one in my 1996 9C1 and they have no clutches either. It's spring loaded cone gears that eat into carrier over time. They work well, but when they wear out the entire carrier is junk.
Gov Locks actually have clutch plates in them as well. They are there to aid in softening the locking action of the diff. And it is correct that GM says to just use gear oil with no friction modifier. However even if the modifer is there it's not going to stop the unit from working or not. It's simply un-needed.
Actually according the GM using the additive in the G80 locker can cause damage.
Some light duty trucks equipped with locking rear axles (G80) may exhibit rear axle chatter, especially when turning a corner from a stop.
This condition of alternate engagement and disengagement of clutches in differential assembly is usually caused by contaminated axle lubricant.
To correct this condition, drain and refill the rear axle. The use of any additive in locking rear axles (G80) is not recommended. Rear axle additives are designed for use in limited slip differentials which are normally installed in cars. All light duty trucks equipped with RPO G80 make use of a locking differential and the use of additives will delay the engagement of the locking mechanism and may decrease axle life.
I have read that too but have also owned a pile of them that ended up with limited slip additive in them. They all worked as normal and only quit when they finally blew up. There is nothing physically in them that the additive can really affect. The flyweight will still move and the locking plate will still engage regardless of the additive. The additive has little affect on mechanical moving parts. It is just a friction modifier for the clutch discs in a conventional clutch pack limited slip.
Most non GM shops have barrels of oil they use for changes and generally it's a limited slip additive equipped oil. I wouldn't be too worried about it.
So really why Gm released that.....who knows. It's full of a lot of mays and could potentially statements. I am pretty sure that eventually GM's factory warranty will include "Shifting the transmissions shift lever from the park position and engaging power to the drive wheels will result in the owner voiding all inferred powertrain warranties".........
I've changed my rear end fluid in my HD and i used a quart of lucas oil stabilizer with another couple quarts of royal purple. It's ben workin good for 20,000 miles or so. You could also run some ams oil.
Yes, regardless what oil you use, synthetic, dino, whatever, good idea to periodically change it- gets hot at times, and stressed. If you check the owners manual and figure the interval on the 'severe service' timetable, probably be conservative- but much normal use is considered severe- short trips, dust, towing, About the only thing that isn't severe is long highway drives-
    250.3k
    No1UKnow
    No1UKnow
  • Who's Online   5 Members, 1 Anonymous, 1,150 Guests (See full list)
    • My take: I don't think seeing up to 200k on the odometer of any of these engines/trucks (2014-to present) is surprising. (Excluding the known DEFECTS, specifically, the 6.2 main/connecting rod bearing issues, the defective lifters, alternatively parts that a recall was issued for - I think there were three.)   250K is my line in the sand, anything over that is 'surprising', but not limited to the engine making it that far but including the truck surrounding it too. (We've talked about this in other posts, why I think the engine isn't the deciding factor for ultimate mileage.)
    • I included the first gen-cylinder de-activation (active fuel management) in my statement.
    • Hello All!   My 2019 Colorado 3.6 LT, 4WD Crew Cab has approximately 77,500 miles and I recently began experiencing the well-known transmission shudder between about 30 and 65 mph. The problem had worsened to the point that I could no longer attribute it to road conditions - and I had decided to bring the truck to the dealer - when recently, I experienced a sudden loss of power while driving at maybe 40 MPH. Several warning lights flashed, the “Check Stabilitrack” message appeared, and the Check Engine, Stabilitrack, and Traction Control icons remained illuminated. The truck regained driving power, but it stayed in a low gear with unusually high RPMs for the speed. (limp mode?) Because I was only about two miles from home, driving slowly, I was able to make it back and run an OBD-II scan, which showed fault codes U0101, P0700, and U0100. My next trip in the truck was to drive it to the dealer the following day. That trip began normally, but after about a mile I experienced another loss of power, along with the same warning lights and the same “Check Stabilitrack” message. As before the truck remained driveable, but again operated at an abnormally high RPM-to-speed ratio and seemed stuck in a single gear. About a mile later, the dashboard lit up once more, this time displaying “Check 4WD.” Soon after that, I arrived at the dealer. I have verified that the truck still has its original factory transmission fluid, which means it has never received the corrective fluid exchange outlined in GM Technical Service Bulletin #18-NA-355.  That was Thursday of last week and I've heard nothing yet from the dealer.    According to Technical Service Bulletin #18-NA-355 and the build date of my truck, my truck should have the newer LV fluid. I've done a little research and read something about a problem with the wiring harness as well.   Anyone have an insights into this situation?  Thank you!!
    • Having bumper and other body damages can be very frustrating, especially as a result of a parking lot collision/bump. Our team wants to learn more about the damages to your truck so we can look into ways we might be able to help. When you get the chance, please fill out our support form with more details: https://s.gmc.com/support-request . A member of our team will follow up with you as soon as next available. We want to get you enjoying your truck to the fullest again.
    • Did you even read this article?   Even the title of the article says "U.S.-Iran Deal Doesn’t Mean a Swift Return of Oil and Gas Flows"   Remember, crude oil prices are based on FUTURE purchases by the oil companies.  Gas prices are based on FUTURE purchases by the station.  This article stated that many of the oil producing nations have to restart their processes to get the oil produced.  Then the oil has to be shipped to wherever.  And it doesn't get there overnight.  And most of that oil is not coming here. Check out this site:  https://afdc.energy.gov/data/10621   A graph will pop up to show where the US imports their oil from.  Notice that there isn't a lot of import from OPEC and Iraq.  Most of the US import comes from Canada. The US oil produces are selling their oil on the open market, which is why the US fuel costs went up.  So you're correct, the US oil companies are going to slow walk the price downward.
