Its been two months since i've washed my truck, this is its first washed since being lifted on the 22nd March. Also recently debaged (shaved) the badges off the truck. Thought I would share with GM Forum family some pictures. Plan on taking it to Myrtle Beach this weekend, ill try to get some beach shots if possible. Enjoy and feel free to comment.
Now that is sexy. :thumbs:
I know its all over the forum and ive read it countless times but I'll go ahead and ask you. Howd you remove the badging? What method did you use?
Great job, truck looks awesome!
What kind of wax are you using? I know I say this a lot but I love Colinite 845 insulator wax, it shines up awesome and lasts for close to six months!
The bonus is you have to use so little the bottle will probably last at a few years based on a 2 times wax interval.
Awesome stuff imo.
Now that is sexy. :chevy:
Thanks, the method I used was "dental floss," I went through a whole thing, due to the floss getting hot and breaking, but it works with out scratching your paint. I applied Goo Gone to left over adhesive and let sit for a few minutes and then used an old credit card to remove the sticky hard adhesive that couldnt come off with just using a rag and then wiped the rest off with a rag. As for wax, I just used regular turtle wax in bottle. My paint looks shiny cause I spent a whole day "clay baring" it. You will be surprised how much a clay bar will bring out your paint, did it to my wife's Jetta and brought it back to life.
Looks Good? What part of Myrtle Beach are you going to ?
thanks, I went to North Myrtle Beach, we stayed the weekend at the Prince Resort at Cherry Groove Pier. Didnt get a chance to take any beach shots though, but did get a lot of stares and compliment for various people. Amazingly I was able to park my truck in the parking garage with plenty of clearance, the only thing that was hitting was the antenna.
