Average Mph
If you take your odometer reading and divide it by the Engine hours you should come up with your average speed, what is yours?
On my 03 Sierra for example it is 172,348 Miles divided by 4703 Hours would = 36.64 Average MPH
Interesting...I'll go check...
I averaged 74.30 as I drove (code 3) to the hospital today. 16 miles in 13 minutes...
true that, i'll check my hours tommrow but my average speed is going to way different then yours because my truck idles a ton in the winter...
1999 GMC 1500 5.3l 2wd
176,485 m / 5330.4 hrs = 33.109147531142128170493771574366 or 33.11
Jbo
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
