Occasional Bad Idle
I have a 2004 Z71 with just over 50k miles on it. Since January I have been experiencing an occasional low idle...almost to the point that the truck shuts off. This happens randomly, but when it happens it does it a few times in a row, then runs fine for a few days. This happens only when I am at a stop sign or red light and has happened when creeping along in stop and go traffic. The truck drives fine when running at highway speeds and I have not noticed any issues when accelerating. I cleaned the throttle body back in December so i am pretty sure that is not the problem. I tried searching for similar problems on this forum, but the posts I found refer to a potential problem with the Idle Air Control (IAC) valve. From what I understand, the IAC should be on the driver's side of the throttle body, but this location in my truck only has a empty spot there. I have a Hayne's manual for a 2002 Silverado and have referenced it for this issue. All of the symptoms point to a possible problem with the IAC...I just don't know where it is located on my engine! Can someone point me in the right direction? Thanks!
your 2004 has an electronic throttle body so it has no Idle Air Control Valve like the cable controlled models. On the electronic throttle control models the computer activates the servo motor to crack the throttle as needed.
Most likely you need to do two things:
1. remove the throttle body and clean it thoroughly - front and back. It's only 3 nuts and a wiring harness disconnect to remove. (I know you said you did this, do it again ;))
2. Clean the Mass Air Flow meter - this is located next to the air filter in the intake tubing, ONLY use the specific MAF cleaner available from auto part stores and follow the directions, other cleaners will leave a residue and interfere with readings. Do not touch the sensor wires with your hands.
    • I am sorry if this was misleading. That was a document attached to our most recent work order number (Doc# 7105804) that summarized all the current updates. These programs were ‘redone’ in the past but these versions dated 4/1/2016 were the ones that actually made all of the problems disappear. These programs were relayed to the dealer from the technical services group at GM. Here is the exact wording on the last work order:   “Front view camera reprogramming with SPS. A new version of FCM software was released to the service dept. In addition to providing general robustness and stability enhancements, this update includes all enhancements from previous software version releases. SPS camera and calibrate camera. OLH to perform extended camera relearn procedure after camera calibration. Would not take with first GDS learn. Front camera SPS – BDYZ333157450 GDS2 – camera road calibration performed 2810835 Front view camera reprogramming with SPS LT 0.6 OLH – extended camera relearn procedure OLH LT 1.5”   I got the truck back on 4/8 – since that time it has been great no problems whatsoever. The lane keep assist, active cruise control and AEB all work very well around town and at highway speeds up to 80mph. During this time I had been away for a week and purposely let the battery sit without a batter tender. Even with the battery a bit lower there were no problems exhibited. I really think this one has it fixed after dealing with these issues over a couple of years. These new programs and relearn process when completed seem to make all the parts (and newer replacement parts) ‘talk’ to each other without any glitches. Hope this helps
    • I turned 72 today. My day began with a trip to the pharmacy to pickup meds for me and the dog and then a stop at my chiropractor before heading home. Once home I started the job of replacing the rear brake pads and one rotor on our 2018 Silverado which will probably end up taking me 3 days to finish, gotta pace myself you know. Sometimes I question myself on why I still do most of my own repairs but if I wasn't then it's more than likely I would be sitting in front of the TV all day. It seems like the list of things I need to do gets longer no matter what I accomplish. I'm not complaining but being retired was so much easier when I was 62.   Peace
    • google "bathub failure curve". Basically, any part of the vehicle can fail at any time.  It starts off as being more likely (early failure), then the failure rate goes down (but does not go to zero), then it goes up over time because it wears/ages out.
    • I went from every other day to about once in five since the rain abated. I'm not unhappy about that. Took most of the month for the ditches to dry enough to mow.
    • Good for you and her!   Lots of brushing and grooming to be done
