How Can I Tell If Afm Is Active?
I just bought a 2008 4x4 (5.3L) Sierra with 30k on it. I really like the truck. It doesn't even know my boat is back there.
After pulling up the VIN I noticed that it has (at least according to sheet) AFM feature. I'm assuming this is standard on all of these trucks. Is there any indication when it's active? The DIC only has the reset and no buttons, so I don't know if that's where it should indicate. TIA.
My truck has the DIC with the 4 button. In the same display as the Instantaneous Mileage, there is a V8 Mode or a V4 Mode showing.
Sounds like you don't have a DIC :dunno:
Lots of people have added this to their trucks. Sounds like it's pretty straightforward, but I've never done it personally. Do a search and theres lots of thread about it. But read about it here to start: http://www.gm-trucks.com/forums/index.php?showtopic=63291
Bottom line is this my friend, ALL 5.3L latest body style have AFM. They all will shift from 8 to 4 cyclinders.
Now the 4.8, no.
Now, if you get an exhaust you'll be able to tell much easier. Here's what you do.
You drive on the hwy on a straight and cruise at like say 70. Don't push the gas hard and slightly let off, just slightly but keep gas on. Now listen to the motor closely. After keeping steady foot now gently hit the gas more and you'll hear the rough sound turn smooth.
That is it switching.
Now, that being said, you need an exhaust to hear it well. I hear mine all day everyday. I adjusted my exhaust and piping today. I took the magnaflow that was connected to the stock pipe that leads to the back of the truck. I then cut the pipe, moved the exhaust closer to the converters, had piping bent and now the exhaust comes out in front of the rear tire. I then put a new different resonator tip on and it completely changed the sound. It sounds good I might add. But back to the story I can go on the hwy and when in 4cyl mode it sounds like a diesel, literally. But once I hit the gas it'll sound like a normal V8.
Try it out and you'll see....
Now the 4.8, no.
I have a stock exhaust, as far as I know (bought it used), but I too can tell when it shifts by the sound, even with the windows up.
    JWeather
    JWeather
  • Who's Online   3 Members, 0 Anonymous, 332 Guests (See full list)
