2009 5.3 Engine Shaking At Idle
My 09 Silverado with the 5.3 and 4 spd automatic trans has a shake at idle. The truck has 4,100 miles on it now.
I will be sitting there with the truck in park with the emerg brake on and every once in a while the truck will start to rock side to side.
I have noticed this several times.
I also noticed when the truck is cold and I drive down the street to the first stop sign and I make a complete stop, and I slowly release the brake just enough for the truck to start rolling, the truck starts a mild surging. I would think the V8 would be smooth all the time.
I called the local dealer to see about bringing the truck in to have them look at it. The guy said that all of the 5.3's have a loping to them. It will be smooth and then start to shake and then be smooth again. He basically told me that unless the engine light came on they really had nothing to go on. They could check the computer but he said if I had any of the HVAC system on it would cause the engine shaking to be more noticable.
To me this doesn't seem right, but that is why I am here asking if you have noticed this on your truck or heard if this is normal.
Any ideas?
Drive Safe
mine had this same exact problem. i recently got a free superchips cortex, ran the performance tune and turned off the AFM and ran premium gas. no more issues at all, dont know if its the gas or the AFM but i know exactly what you're talking about, almost seems like it has a cam in it the way it idles
ya my '08 does the same...like buddy there said, feels like you have a cam in it...
I dont know if its been considered, but could it just be the Engine mounting brackets allowing to much movement...?? On my previous 03" Jetta 1.8T engine, it moved like you mentioned and I went ahead and purchased aftermarket performance engine brackets which stopped all engine vibration.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
