Almost Made A Decision
Which Lift
31 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Ok, I have narrowed it down to two lifts finally.
Zone 5" $1295.99 (Free shipping atm)
Comes with new struts and strut spacers
Only difference between the 4.5" and 5.5" is shorter/longer struts. This helps if I decide to go to 35's later, I can just buy the longers struts.
RCX 5" $1149.95
Comes with just a strut spacer
Only difference between the 5" and 7.5" is the strut spacer and rear block, so I can order those 2 and go bigger later if I wanted.
After researching alot, has none of the issues the 3" does/did.
Is the zone worth the additional $150 that could be applied to tires and wheels? For the same price as zone, I can get the RCX 7.5".
Zone wins hands down. New struts win over spacers anyday IMO first of all. Replacement struts will provide a much better ride quality than spacers. Also both the RC and Zone kits drop the diff 5", so if you were to add the larger struts of the Zone or larger spacers of the RC kit later, you have some things to consider. With the zone, it would be like adding a 1.5" leveling kit to a stock truck, which would keep your CV angles in a good position. With the RC kit it's like having a 2.5" spacer, so the angles are a bit more extreme. RC also requires you to cut off the droop stops, so the UCA's can reach the knuckles on their 7.5" kit. So the RC 7.5" suspension kit would be essentially maxed out from the get go.
The Zone is no brainer to me because it is very similar to the BDS kits, and also because I have been burned by Rough Country. But besides that, Zone is a better built system.
Oh and just so you know, the Zone kit uses only struts and not spacers to achieve the front lift.
They're CV spacers.
Wow, I am a total friggin tard, I knew that and have no idea why I forgot that lol..
Was also told by a vendor for both kits that you cant upgrade the front shocks on the zone because they are special length, but you can on the rcx.
The kits are very similar, RC is cheaper but you dont get new coilovers. Depends on if the coilovers are worth the extra $$$ to you.
My advice, read the installation instructions and determine which one you are more comfortable with.
Are you installing the lift yourself? If so, you need to bring your old struts to a shop to have the springs put on the new struts with the Zone kit.
Upgrade as in higher quality, or longer length? Either way that is nonsense.
He said if I wanted to upgrade to a better quality shock, I couldnt on the zone because of their custom size.
Man this is killing me lol. I got this site choosing Zone and the other forum I am on choosing RCX. I really thought one would wiin on both sites..
Well, after reading both sets of instructions, RCX has less modifications done to the factory components. On zone, you have to cut down the tie rods ends and the sterring links. RCX has you drill a new hole. Zone also has you cut up the differential in 2 spots, one to clear the newcomponents and the other so that the skid plate clears, rcx doesnt do this. They both require cutting the cross member in the same spot and the dust shield.
Ok, I think I have a better understanding of what he ment. Zone uses a custom length strut that are produced for them, therefore if you choose to upgrade to a better strut, or if you blow a strut for some reason, you cant get one from a regular vendor/auto parts store, you have to order it from zone.
Yes upgrading shocks is easier for the RC because of using the OEM size. You have to cut the tie rod ends on the RC too.
Edit: Not having to grind on the front differential swayed me towards the RC too, those are heat fins that are there for a reason.
Was that on the 7.5" or the 5". I read the directions this morning and it says nothing about cutting them. On the 5", it onlys says you have to drill a hole.
Both 7.5 and 5, I personally had to on my 7.5 and have heard from enough people the 5 needs it cut too. It's not really a big deal, not like your ever going to drop back down to stock.
Yeah, I reread the instructions and at the begining it says you may need to do it lol. Anyways, I am ordering the Zone. I looked at the diff mods and its not the cooling vents that get modified, so I am good with it. The RCX is also a month back ordered.
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
