  • 5 months later...
  • 9 months later...
I'm in Centerville, Ohio.
That is just south of Dayton.
I enjoyed the location post that said I live in ...., near .... and wauseon!
It was funny to me for someone from a small town to reference other small towns to let everyone know where they were from!
The only reason I know Wauseon is that I taught the high school drum line there for a year or two and I was in the Glassmen.
New chic to the site. I have a 2002 Trailblazer 6 cylinder, inline with 103K miles. I do my own oils changes and I tried to change the spark plugs (couldn't get the last one and I am a woman with small hands!!). I want to start doing more stuff; ie: finish changing the spark plugs, drain coolant, etc. Getting sick of paying the dealer's prices when I KNOW I can do most of this for half the price.
Any one in or around the Cincinnati area that would be willing to spend a couple hours showing me the "tricks of the trade"? I have the Haynes guide but it's not as good as having someone there to answer questions, etc. It would merely be a Staurday or a Sunday morning, meals could be included ;-)
If interested, send me an email: [email protected]
Thanks!
Susan
i live in dayton ohio , and im going to the lima truck jamboree , just registered my truck today actually , hope to see some of yall out there :D  :cheers:
Where at in Dayton? I live in Lewisburg.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
