Tire Size With 3.5" Combo Kit
And Matt, when you say trim, you just mean the black plastic in the fender well right? Not the front bumper, right?
Metal.
To fit those tires on +18mm offset wheels (probably 9" wide) you'll want a 3" body lift and 1.5 or 2" leveling kit.
I'm at 3" with just my BL... wasn't even close to fitting... i would've needed at least another 1" to maaaaybe not trim the metal
Valley, I have 18x8.5 +18 wheels running 275/70R18 tires. The combo looks good together and I have not had any rubbing issues. My post with pictures is on page 2 here.
they're 10mm more narrow than 285s and 30mm more narrow than 305s.
275s are still almost 11" wide so they're not too skinny for 7-9" wheels by any means.
