Seat Covers
I have a 2008 silverado LTZ with leather bucket seats (tan/taupe). I wanted to protect them so I bought a set of Gm seat covers($180). I only installed the drivers seat. It is a very good fit, but I recently removed the seat cover and had the seats recovered in perforated suede leather. The drivers cover is in very good condition and the passenger is like new. Some how I misplaced one head rest cover, but I did not install either as I think it looks pretty lame anyway. Anyway, I would like to sell them for $75 plus shipping. Dennis
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
