guido1869 Posted June 6, 2010 Posted June 6, 2010 Pull the bed or drop the tank? 99 silvy ext cab Dealer put the computer on my silvy and told me that the pump is down to 12psi. I can get some people to help me pull the bed off so that isn't a problem.
redvett Posted June 6, 2010 Posted June 6, 2010 Pull the box is easier since you dont have to lift the gas & tank and your just looking down at the tank to remove the pump. Just takes 3 people to lift box back a bit. Pull the bed or drop the tank?99 silvy ext cab Dealer put the computer on my silvy and told me that the pump is down to 12psi. I can get some people to help me pull the bed off so that isn't a problem.
SLESierra Posted June 6, 2010 Posted June 6, 2010 Pull the bed or drop the tank?99 silvy ext cab Dealer put the computer on my silvy and told me that the pump is down to 12psi. I can get some people to help me pull the bed off so that isn't a problem. Bed is safest/easiest imho especially if you live in the rust belt
KBinCT Posted June 6, 2010 Posted June 6, 2010 I removed the bed when I replaced the fuel pump on my 99 Silverado. The bed bolts were rusted some and one snapped but it was still easier then dropping the tank. Once the bed was off it took just a few minutes to replace the pump and have it ready for the bed to go back on.
