Paint Chrome Bumpers?
I was wondering if painting my chrome bumpers gloss black would give it a more sporty look, or make it look like sh*t. I want many opinions and criticism on the subject! This is my first topic so I don't know how to resize my pics so I can upload them. But, when I figure out, if I do, I will post pics of what it is now, and if I get the go ahead, what it looks like after I'm done. :thumbs:
Ironically, I want to do the same with my truck, but just the front only. I had one body shop tell me that they couldn't paint the chrome bumper, but would paint one from GM that's primered for $250. Another body shop told me $150 to paint the chrome one my color (silver birch), he said they'd put a chemical on the chrome to "etch" it, then prime it, and then paint it to make it look factory.
Sry, if I got too far off.
I think the gloss black on yours would look awesome!
Thanks, I was gonna take the spray gun to mine, after sanding it, with some self-etching base coat, then flat black it, then finish it off with some shiny protective enamel. Sorry about that disgracefully written sentence! :lol:
Thanks, I was gonna take the spray gun to mine, after sanding it, with some self-etching base coat, then flat black it, then finish it off with some shiny protective enamel. Sorry about that disgracefully written sentence! :thumbs:
Sounds like you got it figured out! I'm anxious to see your results.
I just don't think black bumpers on a white truck would look right but that's just my opinion. I would definitely try to find some pics to see what it looks like before you go ahead and do it.
That's easy for you to say, you're lucky you have a black truck. I wish mine was black. :thumbs: Yeah, it's hard to find pictures of them like that, I guess it'll be unique if I do it.
Try Photoshopping it first. It isn't exactly a bolt-on/off mod. :thumbs:
You just have to know what it's going to look like and be absolutely sure this is what you want before you go ahead and do it.
Yeah, it isn't exactly a bolt on/off type mod, maybe I'll just go ahead and install my 2" drop until I get enough opinions to support what I wanna do. Should I paint them white instead? :thumbs:
My black SD came with painted front/back bumpers, and I love the look (as it color matches the truck). I did color match the front on my 2000 Pewter truck (body shop sanded the grill/front valence and painted it to match). That looked really good.
On the back, it may look weird due to the black plastic step on the top of the bumper.
Well, I was gonna get my 2" drop on the pickup today, but the plans changed. I got up under the truck, laying on my back on the grass underneath the truck, and I got out two bolts for the hitch. Stupid GM had to put the hitch right in the way of the bottom shackle bolt! :D Those bolts were tight and I put my arms on the ground to rest for a second, and all the sudden I feel this thing crawl up my arm(I didn't care at first but then I felt this shock-like pain). The pain felt like I grabbed a wet extension cord(kind of a surge like feeling). I looked at the top of my arm and it was a brown recluse spider, needless to say I freaked out and hit my head on the hitch, getting up. I had to go to the hospital and I just got back, this is gonna suck, I can already feel the skin in my arm dying. :)
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
