Snow Plow On 1500 Crew
fast86gn
Yes, they are gone. My wife commented, " If your driving it to church next week again........" Yeah there gone now!
  • 10 months later...
  • Replies 34
  • 1 month later...
Leveling kit on a plow rig??????????????
That ain't gonna help with a ground clearance issue. Ballast in the bed along
with a few turns of the t-bars will bring up the nose a bit.
I beg to differ...i put on a set of bilsteins and 1 inch bigger tires....raised the front end up quite a bit...clears the curbs and approaches perfect now.
DUH! Sure IF you want to MODIFY a truck for a plow....................
Sure .....run right out and spend $$$$$$$ STUPIDLY when installing a plow!
There is a correct way and a incorrect way.
I think you missed the OPs wants and intentions.
BTW: He posted TWO months ago....so your late to the party!
  • 1 year later...
well here we are years later and all is still well with my truck i'm now at 124k miles and i had to do the front axles about a week ago. the truck pushes snow well and has no problems with the Western HTS and 2 inch level. i just threw the plow on last week to make sure she is ready for yet another season of white stuff. if you are local and want to see the setup let me know.
there is one problem that i do get when the blade is on that is common to all gm trucks because of where the temp sensor is located. if you drive with plow up the air behind the blade becomes very hot and the exterior temp sensor thinks it is summer outside and your cabin heat with electronic control will not be as hot as the sensor starts to climb. easy solution is to drop the blade as low as you can or simply stop for a minute and let the outside air cool of the sensor again.
    RyGuy43
    RyGuy43
  • Who's Online   2 Members, 0 Anonymous, 414 Guests (See full list)
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
