Which Add-a-leaf To Get
as title says....
tuff country
http://www.suspensionconnection.com/cgi-bi...scon/81350.html
or general spring
http://www.generalspringkc.com/index.php?p...nt=549&pg=1
and if general spring what size.... will there be a noticeable difference in ride between the 440LB spring over the 844LB spring?
the only thing that really goes in my bed is my fourwheeler. also will tow a 4 place snowmobile trailer quite often this winter
Just looking at them the General appears to be the more finished kit with the proper clips and pads. It shouldn't ride that much worse between the two. A 2500 or 3500 truck has heavier springs than your truck with any add a leaf and they ride fine.
signing on because i was thinking the same thing recently. i wanted an extra inch or two without a lift kit and was thinking about an add a leaf system, but wasnt sure what goes into it.
Its not much of a system. Its an extra leaf that goes on the bottom (on top of the over0load) of the other leafs.
