Another Thumbs Up Or Rc 2" Level Kit
Ooops...thats supposed to say "another thumbs up FOR the RC 2" Level Kit"
Went ahead and threw on the RC kit over the weekend. After reading a few posts here I decided to go without disconnecting upper ball joint. I just removed the sway bar and lower strut bolts, ratchet strapped the control arm down to the bumpstop, and used a bottle jack to push up on the strut just a hair so the blocks would go in. The first side took about 45 min, but after doin one the other only took about 20 min. Also had 20% tint and replaced stock muffler with 14 inch Magnaflow. Watcha think?
Looks good...what's next, it gets addicting real fast :lol:
Just read that Justin from BlackBear Performance is doin a group tune about 2.5 hrs north of me in Indianapolis. Thinkin about biting the bullet on that. I had a tuned 2000 silverado before this one and this one just feels pokey...lol.
did you take it somewhere to get an alignment after? a couple shops around here will do the alignment, others leave it up to the customer after they pick the truck up
also - a shop here recommended the 2.25" ready-lift kit over the RC 2" kit.
I love the Magnaflow Kblaze. I fell in love with it on my 2000 i traded for this truck so i went back with the same thing this time around.
ZCS---Yeah I had it aligned afterwards. It threw the toe off quite a bit, but they didn't have to touch camber or caster. It was between the RL and RC for me, but I liked pics that i saw of trucks with the RC better......The RC was also cheaper, easier to install, and has a proven track record here and on other sites.
Did they have a reason for saying this?
BD,
Truck looks good! I had a Magnaflow on my 2k, cat back system, and miss it! Do you have any drone at all?
Chris
BD,
Chris
They suggested the Ready Lift just because that extra 1/4" inch made the truck "perfectly level." I ended up going w/ the 2" RC kit anyways mainly because of what everyone else had on here based on personal experiences...oh and of course it was cheaper.
BD,
Chris
There is just a little while accelerating from normally from a top at about 1900rpm in each gear. Other than that cruisin down the interstate and such is fine. Hadn't towed yet so i don't know how that sounds. Its way, way less drone than any other of the small, loud mufflers I've had.
Not trying to hijack the thread, there just are plenty of 2" RC threads and didn't want to make another...just adding to it!
2 before shots:
2 after shots:
3" body lift + new tires to come
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
