Looking for a 4 hi (headlight) mod. Saw it somewhere...?
There is a kit I bought on eBay that when you turn your brights on it includes the fogs if that would be anything you'd be interested in, works damn good other than I wasn't too big on the scotch lock they sent so I soldered and heat shrank my connections.
900 series trucks are already 4 high
I know they do the high 4, the kit I'm talking about that I installed doesn't let the factory fog lights cancell out in high beam
  • 4 months later...
Anyone try adding an LED off-road light bar behind grille to make it hide away, but add the extra light? End goal for the vmax of mine is a zone 3" lift and wheels n tires but was considering a off road bar but want it hide it. Looking for mounting suggestions without cutting grille just let it shine throughout the mesh
I believe RIGID LEDS makes a kit to install the little square LEDS in the FOG LIGHT hole not what you want but gets you "closer"
40" light bar
40" light bar
That looks great, and pretty bad a$$ if I do say so myself. Where did you get the light bar
  • 8 months later...
Rigid Industries makes the fog light mount for ~$70-80: http://www.rigidindustries.com/mounting-options/40337
You basically get to choose two sets of the D-Series lights to go with it. The sets run around $200 each. I went with one set of the new DOT/SAE approved ones, and one set of white/spot offroad ones.
The light strips behind the grille I did just for fun haha. Cost about $30
The headlights are from spyder, and the bulbs in them are PIAA Xtreme white plus. $300 for the headlights, $100 for the bulbs.
I did all of the work myself so no labor cost :)
Just looked again. $101cdn for the mount, $253cdn for each D2 light. = much $$$$ lol Looks great though!
The D2 is more expensive than the Dually, but they're the same size. Both can fit with this kit. The main difference is the D2 contains 6 LED's per cube, and the Dually only 4. The beam patterns also differ. I went with the Dually.
can I ask why?
can I ask why?
The DOT/SAE approved fog light is only available in the Dually out of the 2. I really wanted legal ones tied into my stock fog switch. Then for the OffRoad only ones, it came down to cost.
I've actually ordered 2 more sets since, and I'm hoping to mount them in the next couple of weeks here. I'll post some pics when I do.
    tblt44
    tblt44
  • Who's Online   1 Member, 0 Anonymous, 394 Guests (See full list)
