How To Find Out What Gear Ratio Is On An Older Truck?
I was told it is not part of the VIN. So how does a guy figure out which ratio a 1500 or 2500 have? I am looking for a used truck, so trying to figure out a way to ID the differential in a truck.
Code should be listed on a sticker in the glove box.
Check the rpo codes on the RPO sticker on the glovebox
GU2 = 2.73 Ratio
GU4 = 3.08 Ratio
GU5 = 3.23 Ratio
GU6 = 3.42 Ratio
GT4 = 3.73 Ratio
GT5 = 4.10 Ratio
Actually you can run the VIN decoder above (Sticky) and it will tell you gear ratio, I just did it on a 95.
