5.3l 210 Degrees Theromstat
Hey Guys,
Have any of you considered changing the stock 210 degree thermostat. I would like to replace with like 185 degree. I just don't like the engine running that hot, I know GM engineers probably designed the trucks this way for MPG's. My 1995 5.7L K1500 silverado runs a 185 degree which is perfect. I most likely will change it after a tune, just wanted to see if anyone else has done this and to get your opinion.
Thanks in advance,
Daniel
Hey Guys,
Thanks in advance,
Daniel
A 185 should cause it to set a coolant not reaching operating temperature code and a decrease in drivability/fuel mileage. I wouldn't do it, there isn't really any good reason to have it that cold.
Hey Guys,
Thanks in advance,
Daniel
I thought that would be the case of like 160 or 170 degree theromstat. Do you have any idea whats the lowest temperature I can go with that wont affect the coolant temperature sensor, maybe a 190?
195 was the OE 'stat for that engine...
+1
195 degree thermostat is what comes in these.
These engines need to run at a higher temp in order to burn off condensation in the oil. I would not recommend swapping out the stock thermostat.
Go to any board where the guys are running LS based motors and ask that question. You will get answers both ways. Most guys that do have their cars (Camaro, Corvette, GTO) tuned are running cooler thermostats. When you have a tune done, let the tuner know so he can adjust for it. Having said that, I run the stock thermostat in mine and have no intentions of changing to anything else.
http://ls1tech.com/forums/
http://forums.corvetteforum.com/c5-tech-1/
http://forums.corvetteforum.com/c5-scan-and-tune-91/
I ran a 160* tstat in my 02 Camaro SS. I also had a H/C package and was tuned for it. Did really make no difference whatsoever. Don't mess with something that works.
your stock gauge is just something to look at.. It is not running @ 210,, They run right at the 195-198 range per my scangauge.. I have checked the temps in my 01 silvy and 04 tahoe, and even though the gauge shows right near the 210, they're not that hot..
The engine is designed to run that temp,, and running at a lower temp will cause accelerated engine wear, higher emissions, lower fuel econ, lower power, the list goes on..
One thing to check is your clutch fan.. I just replaced mine(due to crappy ac at idle), and it's made a hellava difference with the ac,, so you know the cooling had to be less efficent..
Lower temp thermostats are an old school Hot Rodder trick that simply doesn't apply to many street driven vehicles anymore. These engines are designed to operate at these temps (whether we think they should or not) and as Jenna mentioned, the support systems are all made to operate correctly at these temps too.
Best to leave well enough alone.
    • I am having similar issues.. 08, 4.8L granted I did had a fender bender and minor damage up front passenger side but I don’t think it had anything to do with it.. I had the high and low pressure checked and my fan for my radiator keeps coming on.. replaced the pressure switch and don’t want to keep throwing parts at it. I did have some minor problems here and there like on long road trips sometimes the ac would get a little warm and then on the highway as soon as I give it a little gas or get a little heavier on the petal it started running cooler. Never had an issue with the ac besides the here and there.. but I also started having issues when I fuel up now it takes a bit to start ( super embarrassing) it runs fine and once started ( only happens after fueling up) starts fine any other time. Could they be related?
    • Spent a small fortune on fuel this weekend.   $6.69 diesel, 18 gallons of that. $6.99 92-octane ethanol free, 10 gallons of that for yard machines $5.59 87-octane for one of the cars, 11 gallons.   $250+ and I didn't even get a tug.   Hormuz ain't Hormuzin again, did not see that coming...LOL
    • Appreciate the advice. I've watched multiple videos. Most showing the most complex for those that have a center console, to one that showed maybe 2 pieces of trim being removed, like 6 screws, pulling back the screen and switch assembly, and installing the inline module. And this was a new/newer Silverado. That didn't look too bad. All the others show alot of trim pieces that need to be removed. I've broken those kind of tabs/clips on my C8 Corvette trying to get to the battery, and that was a lot less clips than what I think is involved here after watching multiple videos and looking at my dash today. I have one on the way. Called a reputable stereo place about installing it and got a "minimum" price of $175. Ouch! Looking forward to seeing what the instructions have to say.
    • Hard to say what the issue might be. Anything from the ability to cool the AC condenser up front, to blend door issues in the HVAC unit, to refrigerant charge, to compressor issues or issues in the lines.   Report back what the techs find on the 29th.   GM has service publications which list acceptable vent temperatures and AC pressures at given ambient temps and humidity. They probably won't touch the system if it's operating within those ranges.   I'm also surprised to hear your 2024 with the L8T is still using R134a? I was pretty sure the HD's had switched to the new refrigerant around 2020.
