Painted 18" Z71 Wheels
well,..I got a litttle out of hand with Autocad. I wanted to see what my stock wheel would look like with the inners blacked out.,..and well,..went crazy from there. I really like the look of the last one,..havent decided whether to paint of powder coat,...probably leaning towards paint.
I had all these individually done on top of a wheel and tire photo,..but for some reason when I exported the file ,..the photo was distorted....and Im not that good with photoshop.,...so use ur imaginanation.
sorry for the poor quality.
For those of who who are gonna say it,..no,..im not buying aftermarket wheels. I like the stockers, and keeping the truck subtle,...and have a budget.
Looks cool. a Nice twist on the stock wheel. I agree, either last or second last ones are nicest IMO.
I'm thinking of doing this to my stock rims. How would you paint it so that the paint wouldn't flake off overtime? Yeah, the last one looks the best, the more black the better. Or, maybe I shouldn't have said that. :thumbs:
I think dupicolor makes "wheel" paint. I saw on another chevy forum a link to http://www.chevroletforum.com/forum/showthread.php?t=13837
others have used high temp engine paint, not sure why,.. maybe car paint cant hold up to braking heat and the hot rubber?
I have yet to price out powder coating.
LMAO
  • 5 weeks later...
i thought about powder coating mine since i cant find any wheels i like. I was thinking about doing it like L
Boutin...did you ever go ahead and paint or powdercoat your rims?
not yet,..I suspect it wont be for a while,..havent even had a chance to tint the windows yet. I wish I was a wiz with photoshop so I could have a real visulization...
Well I definitely am no wiz with photoshop, but I grabbed a pic of a truck kind of similar to yours (couldnt get a good pic of your truck) and spent 10 minutes in microsoft Paint to come up with this crude (and i mean crude :fume: ) visual for you. I tried to make it similar to your number one choice in rim.
All crudeness aside, i think it would look awesome if you went with that choice! :cheers:
Well I definitely am no wiz with photoshop, but I grabbed a pic of a truck kind of similar to yours (couldnt get a good pic of your truck) and spent 10 minutes in microsoft Paint to come up with this crude (and i mean crude :chevy: ) visual for you. I tried to make it similar to your number one choice in rim.
whoooooooooohhh....... that looks awesome!!!!!!! same color truck and everything!!!
Thank you so much gforce!!!,..especially the whole sideview of the truck.... I cant wait now. :fume:
I was going to go with the lesser of the black and just paint in between the spokes like the first one,... but now I see it doesnt lose its "chevy" stock appeal., and will be easier to tape/mask off. I going to skip the expense and ordeal of powder coating (as much as I hate too) and paint them semi flat black, and clear them.
Not sure what Im using for product type,..my friends auto body shop will advise me.
Thank you again...
(10 years on autoCAD, ...looks like I need a lesson in microsoft paint...)
(10 years on autoCAD, ...looks like I need a lesson in microsoft paint...) lol :fume:
No problem there Boutin :cheers:
I was a mechanical designer for the mill at a potash mine for a couple years, and even tho I'm quite thorough in autoCAD, mechanical desktop, and Inventor, I still tend to make quick visuals with good ol microsoft paint :chevy:
Good luck with the project, and as always, post some pics when its done!
G
someone photoshop
Just noticed something on your wheels and mine. Those dam ugly wieghts. Two of my wheels have weights that are 3" long.
What other alternitives are there? can there just be weights on the backside (inner) side of the rim,..?? are is it required to be on both sides? Can I ask for adhesive weights?
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
