Dar10ion Posted July 31, 2010 Posted July 31, 2010 While driving I hear a "pop" almost like a backfire. However it's not consistent. Sometimes when accelerating slowly, but mostly when letting off the accelerator. Currently have the check engine light on. Have had the codes read and it's P0496 - Evap Flow during a non-purge condition. Any Help?
Wires Posted July 31, 2010 Posted July 31, 2010 While driving I hear a "pop" almost like a backfire. However it's not consistent. Sometimes when accelerating slowly, but mostly when letting off the accelerator. Currently have the check engine light on. Have had the codes read and it's P0496 - Evap Flow during a non-purge condition. Any Help? Fix the P0496 code, and see if the popping goes away....
Dar10ion Posted August 28, 2010 Author Posted August 28, 2010 Fixed the problem that was causing the engine light, still hear the popping.
Wires Posted August 28, 2010 Posted August 28, 2010 Fixed the problem that was causing the engine light, still hear the popping. Dirty MAF can cause that as well...
RyanbabZ71 Posted August 28, 2010 Posted August 28, 2010 heat shields? Does it happen when the truck is off and parked?
Dar10ion Posted September 1, 2010 Author Posted September 1, 2010 Fixed the problem that was causing the engine light, still hear the popping. Dirty MAF can cause that as well... "MAF"?
Dar10ion Posted September 1, 2010 Author Posted September 1, 2010 heat shields? Does it happen when the truck is off and parked? No only when moving.
sc4808 Posted September 1, 2010 Posted September 1, 2010 Fixed the problem that was causing the engine light, still hear the popping. Dirty MAF can cause that as well... "MAF"? Mass Air Flow Sensor, thats the thing wuth wirtes pluged into it right next to the air filter box (in the air tube)
Dar10ion Posted September 12, 2010 Author Posted September 12, 2010 UPDATE!!!! Had all the software updated. Noise stopped. Runs tremendously better. MPG's up! Thanks for all the suggestions!
