Parking Brake Adjustment?
I have a 2006 1500 LT Ext Cab 4x4 with rear drum brakes. I replaced the shoes yesterday and all is well except the parking brake lever seems to have much more travel than it did before. Rear brakes are adjusted fine, parking brake seems to work fine, pedal just goes almost all the way to the floor which is didnt do before.
I jacked up the rear of the truck and engaged the parking brake to make sure the cable was connected at both rear wheels and it they were both engaged.
I would like to have the same resistance on the parking brake pedal as I did before so I know if I am on a really steep incline or something I am fully enagaged. I checked my manual and it said the parking brake is self adjusting and a search on here seemed limited to disc brakes in the rear.
Any ideas?
1. make sure your e-brake splitter, the metal piece under the driver's side cab area is not twisted funny or angled. make sure the cables going from the splitter are in the correct place and not angled funny either.
2. You could have stretched the cables a bit if you changed the shoes without unhooking the right and left e-brake cable from the e-brake splitter.
3. If the cables seem normal, then your cable adjustment is probably good but you haven't adjusted the shoes correctly. They can be tricky sometimes.
Remember, it will take a few hundred miles for the shoes to mesh well with the drum....but you shouldn't have excessive travel in the e-brake. In fact, mine always became tighter/less distance traveled when engaged and I have put three sets on my Silvy.
No. The brake shoes will not self adjust when braking while moving forward.
What you need to do is to back up fast and then apply brakes. Do this several times. The brake shoe adjustment mechanism works only when braking in reverse.
I remember that is the way it was on 1970's GM cars.
As I said in my original post, the shoes are adjusted fine. Like Hammer said, every time I have replaced brake shoes in the past on this and other vehicles, the parking brake has always gotten tighter (less travel). I did disconnect and reconnect the ebrake cable from the shoes with the opposite end of the cable still connected to the 3 way splitter which would lend some logic to the possibility of stretching the cables. Is it possible that the ebrake cable will continue to "self adjust" over the next few hundred miles?
The parking brake and regular brakes utilize the same brake shoes. Therefore the same adjuster affects both braking operations. unless you adjusted the parking brake cable, then the parking brake pedal feel should not have changed.
I suggest making sure your brake adjusters are not siezed in any way. The wheel cylinder is at the top between the shoes and the adjuster is at the bottom between the shoes. There should be a little arm that ratchets the adjuster when braking in reverse. This is the self adjusting feature. I usually adjust the shoes so that the rear drum will barely go on. There is usually a slot in the backing plate witha rubber plug in it. You can remove the plug and adjust the brakes if necessary. But if this method is necessary it is a sign that something needs attention.
Are you sure the brakes are adjusted correctly?
  • 3 months later...
You can completely forget the notion that you somehow stretched the parking brake cables. If you could stretch them that way, what good would they be if you actually used them? They are not elastic, they are stranded steel.
To adjust the brakes properly after replacing the shoes, back off the parking brake completely, adjust the brakes so the you can just hear the shoes touching the drum (I adjust with the wheels on) as you rotate the wheel. Then adjust the parking brake to the pedal height you prefer.
Maybe something inside the drum with the parking brake cable --
Is the spring that is attached to the shoes that goes around the cable when installed routed back into the clip at the 6 o clock position?
Is the end of the e brake cable securly snapped into the end of the shoe?
They are a bit tricky but the trick i use is to pull the cable out as far as it goes and vise grip the cable so it doesnt go back in-- slide the spring over the cable and secure it into the end -- I usually will depress the e brake pedal down a few times while holding the release and it raises the pedal a bit --
Good luck
    • I have thought an EV might have some practical value in extending the life of the ICE members of ones fleet. Now....I'm convinced of it. I've been letting my better half access Raven (Mitsubishi Mirage) for her needs while Dizzy has been in the shop. Being the fuel freak I am and given the fact Raven is capable of over 60 mpg in clean air on a warm day I was taken back by the wife's ability to take a car that had used a half a tank of gas that to that point had returned a value of 57 mpg and return in with a decimating 51 mpg for that same tank in that same day in a 15 mile round trip of short hop errands and a stop in the drive through at Micky D's.  😱   Trust me on this. It would take the remainder of that tank driven on the highway to return that tank to just 54 mpg. This is not a Mitsubishi issue. This is an ICE issue that is magnified in vehicles capable of such high fuel economy values. On a percentage basis your 1500 does the same thing. Short hopping an ICE consumes a good deal more fuel and in doing so provides zero additional useable outputs. That entire volume of fuel is wasted in diluting the cylinder walls oil films, creating crankcase moisture and acid content and the resultant wear.    Enter the SLATE. All of that is avoided and the ICE's advantage in range and made useful at reduced wear for your ICE!   Kind'a cool.
    • Back in the day people would buy cars based on performance. The charger posted does 0-60 in 3.3 seconds. And it’s fully loaded.  It has a decent warranty and will fit most anyone’s needs. Remember the original Hemi? 90 day warranty. 25K mini truck or that car? I’d go with the car. It wouldn’t fit my perimeter. If I could just talk my wife out of her Genesis. It would be perfect for her.
    • Let's pivot this back. Someone said they wanted pictures.   Even better, there's already video. Pre-prod prototypes are already on the road and they're letting the press drive them.   JerryRigEverything did a good review. I really enjoy his content and EV adventures, so I was thrilled when he had the chance to review a Slate:
    • The Charger EV was stillborn. Wrong car at the wrong price for Dodge's intended audience. Now at a good price with fire-sale discounts, and still not selling, it's still very much the wrong car. Again, Dodge's intended audience. I believe a lot of Stellantis' EV blunders were all under Tavares' regime at Stellantis...the board convinced him to move on. Neat car, just wasn't received on the level that would sustain mass production.   Dodge is headed in a better direction for its core business. I didn't think there was anything left to get excited about re: the Durango after its 15 year run, but they're just now releasing a 392 version that should price out in the low 40's. Nicely done. I'm not sure I would touch anything Stellantis makes with a 10' pole these days, but the Durango is still mostly parts designed like 3 parent companies ago so maybe it's still OK?
