2003 Dodge Ram Heavy Duty
Z71GUY
Well, I was going to this small town today for work when I saw this area fenced off.  Inside this area were around 100+ 2003 Dodge Ram 2500 4 door SLT shortbed 4x4's.  All of them were jet black.  At first I thought it was a huge fleet order, then I noticed all of them were decked out. I later found out that they are all going down the road to a huge area and Dodge has all of the dealers in the NE going to this.  I guess they are going to do a demo for the dealers....
At this point I figured I would get a closer look at them.... I drove up to this area and instantly got goose bumps.  The first thing I saw was this little badge on the front fender that said "HEMI Powered".  ALL 100+ trucks had HEMI's in them....
If I go back this week, I'll take my camera and get some pics...
Eric
seen a blue one this weekend in a labor day parade
There is nothing special other than the hemi badge on the front fender.  They look exactly like the 1500s (UGLY)
Actually the ones I saw sat up a good 2-3" higher than the 1500 models...you could also clearly see the SFA instead of the IFS on the 1500.  These are the two things that tipped me off that they were 2500 series trucks.
Either way, I think they look alot better than the 1/2 tons...
Whaaaat!!  That hemi engine is all i need for it to be special :)
That engine rocks!
That engine rocks!
I agree....I'm a chevy man, but would love to have a Hemi under my hood!
You wouldnt want the one i seen then.  It sounded bad.  Honestly it was knocking pretty bad where i could here it from the sidewalk while watching the parade.  It was hauling 16-18ft trailer (float).  Also there was a 1500 ram behind it and no way did it sit up 2-3 inches higher.  They were both 4x4s too
Also the fronts looked identical.
Just get the 8.1 it is a simi-hemi, always has been always will be.  I had much rather have half hemi as a whole one if you know what I mean.
Well, I hope I get some pic's this week.  The (100+) 2500's that I saw, EASILY sat 2-3" higher.  I'll see if I can get some pics & show you a comparison of the heavy duty's I saw....
Well, i wouldnt want any noisey engine thats for sure.
At least on paper those engines rock :flag:
  • 3 weeks later...
Here is a picture from the main page of pickuptruck.com.
If you ask me, the HD's DO sit up a couple inches higher than the 1500's...
Whaaaat!!  That hemi engine is all i need for it to be special :D
That engine rocks!
This isn't the Hemi of years past.  This is basically a carbon copy of the LS1 and Vortec engines with a Hemispherical combustion chamber which nowadays isn't all uncommon in the industry.
My truck has an internal combustion engine.  The NASA spaceships have internal combustion engines.  I don't see a nameplate making a huge difference.  Plus B&D enterprizes pulls for us and they have a hemi.  These are all Dodge boys.  Their comments are "Well is a alright truck if you don't want to pull a whole lot" and "At 70mph the truck has good power, but getting out of the hole it has trouble get out of it's own smoke.
  • 3 weeks later...
Well I've been a chevy fan for a very long time.My first auto ever was a 60 model apachee stepside shortbed w/slant 6 & posi still have it ,still runs... I've owned a lot of vehicles over the last 25 years All american :)  But 1,a 56 panhard {french} DYNA!!! But anyway ... I've never bought a BRAND NEW vehicle my whole life ... till now..My partner and I recently decided to change that so we started researching every thing about anything with 4 wheels ...4 long months and bookoo test drives including chevy dodge gmc ford datsun nissan toyota and even houlden as well as jeep and so on.....  well...after countless hours days & weeks of deliberation we are the proud owners of a 2003 dodge 2500 4x4 laramie s/crew swb with the 5.7 auto.w/tow and locking diff. options. were set. she loves it and so do I. It felt like gm's 8100 powerwise... and rides like 1500 sierra just without the claustraphobic feel of gm's cramped cabin{up front} that is...  and oh yea 9.5" ground clearance , 8.5"shock travel. Weve already tried that out  :thumb: Gas milage-12c-16h .. for me 14c-17h for her.go figure lol I still love gm. but at 32,800.00 I needed the best bang for the buck...ya know? :)  :D  :D
the 1500 is getting the hemi  in spring   talk about a truck being able to move.
then they are gonna put it in the avenger and the charger prototype.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
