Where To Get A Vvs Harness
Im looking at upgrading my factory radio to a OEM Nav unit with or without DVD (doesnt really matter to me). What I have is a 09 Silverado LT with the non-bose single CD system. Ive been doing some research to see what I need and what I come up with is:
Non-Bose Nav Radio
Nav CD
GPS Antena
VVS Harness
(Correct me if im wrong on these 3 things)
From what I have read I believe I do not have the VVS harness in my truck. So when I get the new radio where can I get a VVS harness. I tried google, ebay and the forum and didnt come up with anything.
Also I would like to keep the onstar and XM ability... If thats an issue trying to upgrade.
Thanks for the help
Non-Bose Nav Radio
Nav CD
GPS Antena
VVS Harness
Thanks for the help
Schram Auto Parts might have it They have the best deal on NAV units!!!!!
Non-Bose Nav Radio
Nav CD
GPS Antena
VVS Harness
Thanks for the help
Here are some on ebay (I bought mine throught that guy!)
http://cgi.ebay.com/GM-CHEVY-SILVERADO-SIE...DefaultDomain_0
and a few more from the search.
http://shop.ebay.com/?_from=R40&_trksi...-All-Categories
Non-Bose Nav Radio
Nav CD
GPS Antena
VVS Harness
Thanks for the help
Great thanks for the help. I was looking on ebaymotors. I think thats why I wasnt able to find any harnesses.
