Here is an image of a quick Google search about these tires on my truck and it's exactly same psi recommendation the Toyo tires company gave me!
I'm not looking for anyone else recommended psi or anything, I'm just looking to see if anyone knew a way to get rid of the factory low psi warning light, because I'm not running high psi and ruining my tires when I'm not towing!
Open the driver's door jamb. What do the cold tire PSI ratings on the tire placard show?
I'm not saying to run it to those numbers, but I would like to know what it says.
Alright, thank you!
I reached out to one GM dealer and they say they weren't able to do it, probably don't want to!
but I might ask another one, and If they won't do it, I did a little bit of research and I think the Autel Makisys Elite II Pro scanner will work, it's just expensive!
