rngr746 Posted August 30, 2010 Posted August 30, 2010 I have a 2007 GMC Sierra and am looking for information on how to wire up the headlights so that when the high beams are switched on the low beams stay on as well. Ideally, I'm looking for a simple step-by-step process using just a relay.
zeven13 Posted August 30, 2010 Posted August 30, 2010 Search. I have a 2007 GMC Sierra and am looking for information on how to wire up the headlights so that when the high beams are switched on the low beams stay on as well. Ideally, I'm looking for a simple step-by-step process using just a relay.
MS3DALE Posted August 30, 2010 Posted August 30, 2010 If your '07 is a GMT900 you don't have to do anything,The low-beams already stay on with the high-beams.
rngr746 Posted August 31, 2010 Author Posted August 31, 2010 I searched and searched and searched... nothing!
fraiolib Posted August 31, 2010 Posted August 31, 2010 I searched and searched and searched... nothing! its not a gmt900???
[email protected] Posted August 31, 2010 Posted August 31, 2010 I searched and searched and searched... nothing! You searched for what? Is it a classic body style or the newest body style?
lsuguy Posted September 1, 2010 Posted September 1, 2010 It's for sure on this site. Again is it a gmt900 ( Newer body style) or gmt800 (not as new body style)?
rngr746 Posted September 1, 2010 Author Posted September 1, 2010 My truck is an 07 Sierra Classic W/T. Hope this helps. I was not aware the body styles made a difference. Thank you for your patience as I learn more...!
redvett Posted September 1, 2010 Posted September 1, 2010 1999 to 2007 is GMT800 2007 & later is a GMT900. Forget the NBS,NNBS its not an accurate designator. My truck is an 07 Sierra Classic W/T. Hope this helps. I was not aware the body styles made a difference. Thank you for your patience as I learn more...!
txab Posted September 2, 2010 Posted September 2, 2010 Here's a thread about how to do it. http://www.dieselplace.com/forum/showthread.php?t=179827
rngr746 Posted September 7, 2010 Author Posted September 7, 2010 Thanks for all the assistance and patience with me during this process. The low beam lights now stay on when I activate the high beams. What I did was to use a 1n4004 diode. I kept the white strip towards the high beam #85 pin relay and ran the other side to the #85 pin on the low beam relay. Everythings workd fine and it sure helps tremendously with the night driving I have to do on rural county roads. Just as an FYI, I tried the same set up with a 30Amp relay and kept blowing the left low beam fuse.
ike-sierra Posted September 7, 2010 Posted September 7, 2010 This mod seeems very easy just 1 stupid question. Where is the connector(s) where you put the diodes? under the dash, side fuse panel, or under the hood fuse box? Any pics would help too thanks.
rngr746 Posted September 7, 2010 Author Posted September 7, 2010 There is no such thing as stupid question!! I forgot to include some information. I used the under the hood fuse box. Refer to diagram on the underside of the fuse box lid. By pulling the highbeam relay, I was able to insert the wire from the diode (white stripe facing this relay) into the #85 pin "socket" for the high beams and then to the #85 pin for the low beams. Hope this helps! I'm not much of a computer type so am unable to post any photos.
