Intake Gasket Failure Symptoms?
Looking for a list of symptoms for intake gasket failure on the throttle body...not talking the coolant intake gaskets...thanks in advance
on the truck in your signature?
if you had a gasket leak around the throttle body you would get high idle, no idle, running lean or running rough. That gasket failing would be extremely rare unless you've been messing around with it, it's a captured o-ring style IIRC, either way I know it's a re-usable gasket, so if you pulled it to check and it was fine you could simply reassemble without need for a new gasket.
what symptoms are you having?
and of course there is no such thing as a coolant issue with the intake manifold on a 5.3L, that's only applicable to the Gen II style motors.
clean the throttle body - unplug it, remove it and clean it thoroughly. I've seen this several time before, there most likely is carbon build upon the back side of the throttle blade that is causing it to stick.
Do you have or have you had an oiled air filter? if so grab a can of MAF sensor cleaner also and follow the instructions (don't touch the wires).
nope always used the ac delco oem filters....i'm just a little nerve racked at the moment with everybody on the core thread telling me that the intake gaskets are failing, i'll have the throttle body cleaned asap..would that cause this random effect though?
Choppy idle is ussually the bigest sign, up and down RPMs.
my idle is stable at 500ish rpms, this happening only seems to occur when moving
interesting, i have never cleaned the maf or the throttlebody so i'll get that done
    HWN808
    HWN808
  • Who's Online   7 Members, 0 Anonymous, 995 Guests (See full list)
    • https://www.gm-trucks.com/why-gm-chose-0w-30-gen-6-v8-oil/   The swing back to reality continues…
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
