2002 8.1 Stalls While Driving.
Hey guys, I have a 2002 2500HD Silverado with the 8.1. Lately it's been stalling on me while driving. If you guys could help diagnose the problem I'd appreciate it. While driving any speed, turning, straight line, at a stop, anything, the truck will just randomly stall and i'll lose power steering and everything (obviously). However when I start the truck up again mere seconds after stalling, it fires right up like nothing happened. What could this be guys? I'm clueless, I'm thinking the fuel pump or something along those lines, but I'd assume if it was the fuel pump it would stall ALOT more than it is. Maybe the alternator or something? I'm at a loss, as I'm no mechanic :) . Any help would be appreciated guys.
Crank Position Sensor. Common problem on early 8.1's. They went to a new design.
DEWFPO
I had the same symptoms. I just replaced the Crank Sensor tonight. It fixed the issues and fixed the hesitation that I've had since I bought the truck.
were is the c p s..located? is it easy to change, and is it something i should worry about on an 04 8.1 with 70,000
  • 1 month later...
Might want to check fuel pressure first. But itis probably the crank sensor. It is on the back of the engine. Difficult to get to. Has one bolt holding it in...and the theres an oring...maybe two. Just make sure it comes out in one piece.
DEWFPO
Does 2004 8.1L an early one ?
DEWFPO
Nobody knows if a 2004 8.1 is in the early ones ?
DEWFPO
Wander were is DEWFPO, just want to know if i ad to worry about that issue ? :thumbs::cry:
DEWFPO
They all pretty much have problems, however the only year which was recalled for it was 2001. If I started to have issues with an 8.1 stalling or stumbling, it would be the first thing I would check on. Otherwise they have the same fuel sender problems as most other GM trucks and I would check that next or possibly a fuel filter. Stubby 10mm wrench to get the sensor out from the top of the back of the block on the driver's side (you will want to use penetrating oil on it first). You should do a crank relearn after this but it is not 100% necessary.
Has anyone ever broke the cps while taking it out, if so how did you get it out.
Mine broke, but was still held together by the three wires. The bottom O-ring got hung up, used some more penetrationg oil and carefully drove it out....got lucky.
it is behind your starter, very easy to fix i just swung mine out of the way, i cant believe how expensive it was tho it was like 60 bucks for a part the size of a golf ball
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
