I'm gettin' close!
General Lee 01
Well, here's the scoop.
I've met this guy at work, and he's got an '85 Silverado Shortbed 4x4, and he's sellin' it.
He put some lift on it, which he did himself.
Everything's new. Motor, Transmission, etc.
What do you guys think?
Of course the first question is how much :flag:
Second did he just put the lift on or did he put the motor and trans. in too? If so, would trust this guy to do this work on a truck that was already yours?
And third. How about some pics? :(
answers...
1. 5k
2. He said (I think) he did it all at relatively the same time, He knows more about trucks than I do, so that's good enough for me. :eek:
I'll try to ask him for pics.
Is he a certified mechanic?  If not, you'd best check out everything at the shop before you buy it.  Having your mechanic take it for a test drive never hurts
5K doesn't sound too bad for it.  what size motor?  350?
No it doesn't, considering he invested 11k in it.
And yes, It's a 350.
I trust him enough to believe he knew what he was doing when he did it (the lift).
Some dealerships will "check-out" a vehicle for you for a charge (usually one hour labor) if you don't have a mechanic friend that can look at it.
Just to be on the safe side I would get it checked out. I just sold my 98 Buick Centry to a friend. He took it and had it checked out first befor he bought it. I was glad that he was willing to do that. If something goes wrong in a couple of months, I would not want him comming back to me saying did you know about this and affecting the friendship.
Oh! get under there and check for leaks.  I've got two, sucks cause I don't wanna park in peoples driveways and get tranny fluid and oil all over their pavement.  I know I wouldn't want it on mine.  I don't understand the tranny fluid though, i replaced the seal and now its leaking again?  (front of rear driveshaft pluggin into transfercase)
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
