Haven't I already seen this truck? I told you to lose the tapout cover for the hitch.
Yes in the newbie post, and why the hate on the cover?
I just don't like fads, like salt life and coexist, all those things don't belong on a vehicle, IMO.
How is MMA a Fad? Been around for years, and clearly not going anywhere soon. Just cuz you dont follow it is no reason to hate on something. I only follow hockey and MMA/UFC, real sports...
Back to why you posted pictures... Truck looks great! I love the look of those wheels with those Goodyear's, I have considered this but would need to trade, no money left in the piggy bank. :cool: Also, the debadging makes the truck look so clean to me. Probably going to be my next mod.
Nice ride! :cheers:
Truck looks great!! I agree about the Tapout hitch cover though. I mean you do you, I don't say get rid of it simply because it says tapout, but if youre going to have a clean looking debadged truck why rock something like that IMO. But it's your ride, and nice looking one at that so drive it how you want. :confused:
Nice truck. I'm on board with losing the Tapout hitch emblem, and I am a big MMA fan. I mean, Tapout is a sponsor, kind of like Condom Depot. You don't see people riding around with Condom Depot hitch covers. I'm just saying.
What he said :fume:
What he said :dunno:
Almost got a camo plug instead hehe
..... You don't see people riding around with Condom Depot hitch covers. I'm just saying.
/going outside to remove hitch cover now :dunno:
Guy called last night my brackets for my steps finally are in, truck gets dropped off Tuesday. Also got trackin order on my KMC XD Spy's will be here Wednesday
