Muffler Question
So today i installed a cherry bomb extreme muffler (SI/DO) on my 05 5.3 1500. Everything else is completely stock. I just cut off the stock muffler, welded the cherry bomb muffler up, with 2 turndowns under the truck. Started it up, and MAN is it loud! Starting to think i may find myself in trouble with local law enforcement. Any suggestions for a SI/SO muffler that is a little louder than the stock OEM muffler, but not so loud that i can barely hear myself talking at times? Thanks for the suggestions.
I have had several tickets for sound ordinance violation...... I have not had to pay a one yet, however the exhaust system is 100 % original GM replacements on that vehicle. It is just one cop that gives me tickets when ever he observes me in that car. So when I take that one out for a drive I simply avoid that cops city in the car.
Find out if you city or state has a sound ordinance on the books. If they do what decibel is it? And are you at that level? Some sound shops that work on cars have meters......
In the town I have been ticketed in several times they state OE exhaust exempt from the sound ordinance.
Jbo
Your problem is the turndowns . They dump the sound and it is reflected back up into the truck from the surface of the road. And you've got two. I'm having good luck with a Dynomax Ultra Flo Welded muffler. Plenty of sound when you get on it and a nice rumble the rest of the time. Check 'em out.
http://www.dynomax.com/
Thanks for the replies. I live in NJ, which is pretty strict on vehicle, so i think im running the risk of trouble. I guess i'll run the cherry bomb for a little till i feel i need to change it or i get a ticket.
I will definitely check out the Dynomax muffler. I still have the tailpipe so i could do a easy swap.
Thanks again.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
