Alright so this one ended up being a different TSB that was not related to the transmission at all. It was the O2 sensor wire that got too close to the exhaust and melted. I guess the 5v reference wire melted, shorted out and caused about 200 codes to populate and the truck to go into limp mode.
https://static.nhtsa.gov/odi/tsbs/2024/MC-10253570-0001.pdf
Would the best option be to use a local dealer? I'll be flying into town, most dealers I've called want to charge to do a used car inspection. Can get expensive if I'm comparing 3+ trucks on the same day, not to mention scheduling.
All I see on CARFAX reports is "Engine/powertrain checked" or "Emissions system serviced" and on a few, "Transmission replaced" or "Valve body replaced" which is concerning. A lot of "Transmission Replaced" prior to 140k so I guess I'll have to plan for some extra cash in case of an emergency.
Is it normal for the 10L80 to downshift hard and flare when coming to a stop? I've now experienced it enough (along with some rear end noise when test driving) that I don't know what's a normal 10L80 in non-sport or Tow-Haul mode. Some trucks downshifted cleanly, others lurched and jerked as the RPMs jumped around even in Normal mode.
I'd go right back to the dealer. If I didn't get satisfaction there, I'd go to a different one. If not there, I'd contact GM. It's under warranty. It's their issue to fix.
A lot of people also forget the old 6spd was pretty good at the torque converter snout wearing into the front of the trans case. Pretty common issue. 6spd was not a perfect trans by any means.
