Running Lean! Help!
tyler.m.13
(I am not asking "will this part fit on my truck". Just to clarify so it doesnt scare off any of you technicians when the first phrase you read is about a new camshaft) I recently installed a more agressive cam, ls2 heads, built tranny, and a higher stall converter in my 2004 GMC Z71 Sierra. (5.3 stock intake and fuel system) I took the truck to the shop to have it dyno tuned today and found a problem. Through the several pulls that weremade I only made 270hp & 268 ftlbs of tourqe at the wheels. This sound good but the computer showed that my injectors were running at full capacity. The tech said this was because my engine was starving for fuel. ( running way lean) At the RPM's the truck was running the injectors shoul have been at about 60% capacity. He tuned everything where it would run better but left the injectors at 100% to get the most power out of it. He said that I should change my fuel pump and filter and after I did it should run pretty rich. If it started running rich this would point out that I had fixed the problem bc the injectors were still turned way up. If this turned out to be the problem I was to bring the truck back to him and let him reset the injector capacity to the correct setting fo rmy application. But I changed the fuel pump/filter to no avail. (2004 sierras have a fuel filter that is integrated into the fuel pump) The truck is still running lean even with the injevtors cranked all the way up. Could this b a fuel pressure regulator problem? If so, where is the fuel pressure regulator located? Anybody else have any ideas? I need to get the truck back to the dyno shop asap. Thanks!
Could be a regulator, but more than likely just a weak fuel pump. Seems to be a common issue.
Well it ended up being the fuel pump. I guess the computer just took a while to recognize that it had the fuel pressure needed. Thanks for the comment though.
    HWN808
    HWN808
  • Who's Online   7 Members, 0 Anonymous, 995 Guests (See full list)
    • https://www.gm-trucks.com/why-gm-chose-0w-30-gen-6-v8-oil/   The swing back to reality continues…
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
